Voltage regulator - JeepForum.com
post #1 of 46 Old 07-16-2011, 02:33 PM Thread Starter
airwolf9090
Voltage regulator
I know the Voltage regulator is in the PCM and i was talking to a buddy who owns a part store and he told me about a guy that had a Voltage regulator problem in his jeep (PCM was his problem) well the guy bought a Voltage regulator for an old chrysler and wired it into the alternator and therefor by-passing the PCM's Voltage regulator all together.... I was wondering if anyone here know how it was done?
Looking online i found this.....
http://store.alternatorparts.com/hd-...rsion-kit.aspx
And i guess doing this will work too?
http://www.cherokeeforum.com/f2/91-c...or-swap-41024/
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #2 of 46 Old 07-16-2011, 07:26 PM
Oldfrog
2007 WK
Why are you wanting to even do it? Is your alternator not charging?
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 46 Old 07-16-2011, 07:39 PM
gothchick
The PCM adjusts the alternator's output based on intake air temp, battery temp, and electrical load. I don't think you can duplicate that functionality with a secondary external voltage regulator.
It could be that your voltage regulation diodes burned out in the alternator itself. If that's the case, there is nothing serviceable inside the alternator and you'll need to replace it as a whole unit.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #4 of 46 Old 07-16-2011, 08:02 PM
ZeeJay1997
I replaced the brushes in mine but it wasn't worth the time it took.
ZeeJay1997 is offline
post #5 of 46 Old 07-16-2011, 08:13 PM Thread Starter
airwolf9090
Well i have went over everything i could today even tried another alternator and its output was the same as the one before.. I even replaced the brushes in the alternator and still the same thing... the regulator is not adjusting the output like it should is my only guess because when i first start it the output is only 13.4V and when i turn on my headlights and foglights, AC and radio the output drops to 12.2V and you can't tell me that is okay i am sick and tired of it dieing at a red light and being to weak to start back up because i played the radio while going to the store.
1996 Jeep ZJ Orvis
post #6 of 46 Old 07-16-2011, 10:03 PM
ZeeJay1997
Have you considered a bad battery?
post #7 of 46 Old 07-16-2011, 10:46 PM Thread Starter
airwolf9090
Yes i have i had it tested at afew different places and all say its good and it stays strong if i don't run nothing but the engine.
1996 Jeep ZJ Orvis
post #8 of 46 Old 07-16-2011, 10:49 PM
ZeeJay1997
Will it hold 12.6 volts overnight?
post #9 of 46 Old 07-17-2011, 12:07 AM Thread Starter
airwolf9090
Yes it will.
1996 Jeep ZJ Orvis
post #10 of 46 Old 07-17-2011, 07:11 AM
shreksbrother
I'm currently experiencing the same problem. My battery is fairly new. Battery/alternator repeatedly test good. Mine is maintaining just over 12v, as well. It never drops below, so the alternator is charging, but I can't run my A/C and headlights without listening to the belt whining.
I'm about to change my belt, hoping against hope the belt has stretched over time (it's old and needs to be replaced). Have you checked your belt tension?
shreksbrother is offline
post #11 of 46 Old 07-17-2011, 10:47 AM Thread Starter
airwolf9090
Yep i have my belt is fine.
1996 Jeep ZJ Orvis
post #12 of 46 Old 07-17-2011, 10:56 AM
Foundrydude
I would imagine there's a 1-wire alternator conversion for older chrysler that fits but it becomes a question of if it's a better use of resources than just fixing the PCM.
Most other makes don't factor temp etc into regulating the alternator. They just let the alternator do it's own thing and it does just fine. So from a function standpoint you're not gonna be missing out on much with a non-stock regulator as long as it functions properly.
Good luck!
Foundrydude is offline
post #13 of 46 Old 07-17-2011, 10:59 AM
ZeeJay1997
I've read where this has been done with ZJs and worked, but as the links says, the CEL will stay on. If your worried about passing emissions, well you know...
post #14 of 46 Old 07-17-2011, 11:06 AM
gothchick
Well... Let's think about this.
1) When you turn the key, the alternator light comes on.
2) This tells the PCM to direct power from the battery to the the starter motor.
3) After the engine is started, the PCM then directs the alternator to split it's power output in two directions:
a) Run the engine
b) Charge the battery (The vehicle's subsystems gets 12v supply from the battery even when the engine is running, not directly from the alternator)
If the battery and alternator check out fine, then it seems like maybe the PCM isn't directing the alternator to keep the battery charged, creating an under-charge condition.
I think I'd either take it in to the dealer to have ODBII dignostics run on it, or check the battery temp sensor (and other sensors), or source a new PCM. Heck, you might just have an old fashioned short somewhere. PITA to chase down...
post #15 of 46 Old 07-20-2011, 06:56 AM
shreksbrother
Hey airwolf, anything further on your issue?
voltage regulator djustice ZJ Grand Cherokee Forum 11 06-18-2011 11:29 AM
95 jgc 5.2 voltage regulator???? help onyx ZJ Grand Cherokee Forum 45 06-16-2011 12:22 AM
Voltage Regulator All2kool ZJ Grand Cherokee Forum 4 12-15-2010 09:37 AM
Voltage Regulator??? grand_champ ZJ Grand Cherokee Forum 2 04-07-2008 05:22 PM
Voltage regulator. atomix3 ZJ Grand Cherokee Forum 5 10-27-2004 09:11 PM
