voltage regulator - JeepForum.com
post #1 of 12 Old 06-15-2011, 10:02 PM Thread Starter
djustice
voltage regulator
96jgc 4.0
ok so my heep has went through 2 batteries so far,the alternator isint charging them...i had autozone test the alternator and they said the voltage regulator was going out.i need to know if the voltage regulator is in the alternator or the pcm...and if its in the pcm how much do those usually cost?
djustice is offline
post #2 of 12 Old 06-15-2011, 10:38 PM
sebian
Voltage regulator is in the PCM. Generally speaking, you are probably looking at spending $200+ for a new PCM.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #3 of 12 Old 06-15-2011, 10:43 PM
freakinheep89
Have someone else test the alternator as well. do not rely on the sole opinion of someone working at autozone, they are generally hired for retail experience over vehicle experience.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #4 of 12 Old 06-15-2011, 10:56 PM
onyx
its the pcm im haveing the same problem a new one is 315$ from kolak@aol.com adds 15+hp or if your lucky enough you may find one at a junk yard however most of the time if they are back they wont allow you to return them if they are bad but hey maybe your lucky wirebrush your grounds.And dissconnect your battery and ground out your positive for 30 secs and clear your comp. mine charges good after it rains and when its cold
onyx is offline
post #5 of 12 Old 06-15-2011, 10:57 PM
onyx
lol sorry texting
onyx is offline
post #6 of 12 Old 06-16-2011, 08:49 AM Thread Starter
djustice
most of the ones i see are the jet performace pcms... could i use a stock one off a junked jeep? my buddy has an out of commision 99 jgc could i swipe the one off his?
djustice is offline
post #7 of 12 Old 06-16-2011, 10:06 AM
JS97ZJ
Originally Posted by djustice View Post
96jgc 4.0
There are times when getting the generator tested will not reveal a bad generator. Other factors could be the cause of the battery not being charged. I had a simular problem with mine and it turned out to be a cold solder connection in the terminal block that house the field connections to the rear ot the generator. Here is the test procedure for eliminating the fault.
JS97ZJ is offline
post #8 of 12 Old 06-16-2011, 12:09 PM Thread Starter
djustice
thx ill give that a shot 1st and yea my voltage gage quit working and the check gages came on too...i found out that i can try n get a pcm from a junker but their numbered and mine has like 3 diffrent ones...i would just have to find 1 with the same number so if anyone has one numbered 56041412 lmk
djustice is offline
post #9 of 12 Old 06-17-2011, 08:29 AM
JS97ZJ
I would eye ball the generator first. If it has high mileage on it, it will start to act up by charging intermittently before finally going completely out. IMO.
Don't just assume it's the PCM, you could be opening up a whole new can of worms. The 99 PCM won't work in the 96. If your looking to go the inexpensive route, I'd try swapping out the generator first with a JY replacement. Doing the tests above to get to the problem and replacing with new is always best.
JS97ZJ is offline
post #10 of 12 Old 06-18-2011, 09:48 AM
onyx
wtf is a generator? are we talking about the alt? you can test it by removeing the batt and lett her run if she stalls its bad if not your fine.
I hate voltage regulators.
onyx is offline
post #11 of 12 Old 06-18-2011, 10:22 AM
Dodgeram1989
1976 FSJ Cherokee
A generator is a alternator
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #12 of 12 Old 06-18-2011, 10:29 AM
JS97ZJ
Disconnecting the battery while the engine is running could fry the PCM.
Years ago vehicles had alternator that did just what the name infers, they produced alternating current, that went into a diode pack (rectifier) that converts the 12v ac into a safe DC voltage.
Today the rectifiers are built into the alternators making them generators of DC voltage.
Before regulators were used, when you went on long trips in you car, in order to keep your battery from over charging, people needed to turn their head lights on. The alternators were always on.
In our jeeps the PCM electronically turns the generators on and off automatically, prolonging the battery's life and saving some fuel by not having the generator on all the time.
JS97ZJ is offline
95 jgc 5.2 voltage regulator???? help onyx ZJ Grand Cherokee Forum 45 06-15-2011 11:22 PM
Voltage Regulator All2kool ZJ Grand Cherokee Forum 4 12-15-2010 08:37 AM
Voltage Regulator??? grand_champ ZJ Grand Cherokee Forum 2 04-07-2008 04:22 PM
Voltage regulator shashank ZJ Grand Cherokee Forum 2 01-22-2007 04:58 PM
Voltage regulator. atomix3 ZJ Grand Cherokee Forum 5 10-27-2004 08:11 PM
