Voltage issues - JeepForum.com
post #1 of 14 Old 07-12-2011, 03:58 PM Thread Starter
CLNinja
CLNinja's Avatar
Voltage issues
Havnt posted here in a while...especially asking a question about my own jeep ..
So my jeep has been sitting for a while , ive been doing some axle work and some power steering work and whatnot and basically i also just dont drive the jeep as much anymore since i have a new DD and the Jeep is just a toy.
I started up the Jeep ( after putting in a brand new battery ) and started it up and it didnt fire right up like it used to but it fired up and idled and ran just fine so i started to drive it to my parents house to do some work to it. well i noticed that the voltage guage was registering very very low.. in the red .. so i kept driving and almost to my parents house check engine light came on ( didnt check it ) i assumed it was because of low voltage. I took the battery back and replaced it with another brand new one ( just exchanged it with another, had only been a week so they swapped it out. )
voltage guage still registers very very low... but it seems to run just fine after it gets started up
im using a new kind of bettery that ive never used before its the Duralast Platinum .. supposed to be the same type of battery as an Optima. maybe its the battery... i dont know... i have a 5.9 alternator in the Jeep so i dont think the alternator is the problem but who knows..it is used after all
any ideas? im gonna get my alternator and bettery checked when i have time but i figured id ask here for ideas in the meantime
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #2 of 14 Old 07-12-2011, 04:01 PM
XOFMOT
Does the voltage read low when driving say on the highway..2000 rpms or so??
XOFMOT is offline
post #3 of 14 Old 07-12-2011, 04:08 PM Thread Starter
CLNinja
CLNinja's Avatar
reads low while driving at 45mph or so .. thats the highest ive taken it like this... revving the engine or driving does not effect where the needle sits, it stays in the same spot very very low on the gauge
Matt
CLNinja is offline
post #4 of 14 Old 07-12-2011, 05:05 PM
sebian
After you get the charging system checked, check your body and block grounds to make sure they are clean and secure. If the grounds are ok, then probably looking at a new PCM.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #5 of 14 Old 07-12-2011, 10:15 PM
onyx
i would check your ground regardless of the batt the alt when running should be at atleast 12 if not id check the alt but check the voltage regulator in the pcm first
onyx is offline
post #6 of 14 Old 07-12-2011, 11:02 PM Thread Starter
CLNinja
CLNinja's Avatar
i have a Mopar Performance PCM so i hope thats not what it is.... those are expensive and hard to come by
if thats what the problem is.. then ill be switching back to a stock PCM
Matt
CLNinja is offline
post #7 of 14 Old 07-15-2011, 10:43 AM
onyx
at advance they have bdu ones for 131.99
onyx is offline
post #8 of 14 Old 07-15-2011, 03:51 PM
rooster51
I would sure investigate and rule out the used alt before even considering a PCM. Your symptoms are not high on the list of bad PCM symptoms. Be sure to check the alt pully for function also.
Terry
rooster51 is offline
post #9 of 14 Old 07-15-2011, 05:59 PM
JeepOrvis97
JeepOrvis97's Avatar
Not to question the obvious but have you checked the volts with an external volt meter? Maybe the gauge is bad???
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #10 of 14 Old 07-15-2011, 06:12 PM
jeep210
If you can use a voltage meter you can do some testing. With engine running, test the battery and it should read in the range of 13-15 volts. If it is reading 12 volts or less the alternator is not charging.
Now, with engine off for these tests, test the battery for voltage. Then test for voltage on large terminal on back of alternator. You should read the same as battery voltage. If you read battery voltage, then the cable from the alternator to the battery should be good. Check that it is clean and tight.
If you do not read battery voltage at the alternator, then you have a fault in the cable going to the battery. There is an inline fuse on this cable.
Finally, start the engine and have some one rev it up a bit. Now test for voltage on the alternator large terminal. You should read 13-15 volts. if it is charging.
Hope this helps and good luck.
jeep210 is offline
post #11 of 14 Old 07-17-2011, 09:56 AM
onyx
also look for any melted or stiff wires that feel brittle sometimes over time the wires will harden and crack like plastic allowing contact
onyx is offline
post #12 of 14 Old 07-17-2011, 10:51 AM
98mopar
You will need a voltmeter. With the engine off the battery should read around 12.4 volts. With the vehicle started and nothing else on (lights, radio, ac, ect) should read right around 14.5 volts. If not then you have an issue. First check battery terminals. Check for loose cables, or corrosion, or frayed ends. Then check your grounds. Also check your alternator fuse. Also check all your connections at your alternator. After all those things you find no faults, then you probably have a bad alternator.
--- 1998 ZJ 5.9 Limited - 4" lift, 31 x 10.50 15, Jet chip, Kenwood Excelon everything, current DD
--- 1996 ZJ Laredo - Parts parts and more parts
--- 1993 ZJ Laredo - 4.0 Bone stock for now (New to me)
98mopar is offline
post #13 of 14 Old 07-17-2011, 06:26 PM
onyx
ive never had an alt go from working on a car if there was a jolt to the system you can kill the pcm
onyx is offline
post #14 of 14 Old 07-17-2011, 06:28 PM
onyx
nothing like the oops when someone connects positive with neg somewhere with a wrench or crosses wires and it costs you $$$$$
onyx is offline
No Voltage mike3800 ZJ Grand Cherokee Forum 3 07-04-2011 03:13 PM
tps voltage 02mudbug ZJ Grand Cherokee Forum 12 02-16-2011 10:10 PM
ZJ Voltage Dip. Bannonjr ZJ Grand Cherokee Forum 6 12-13-2008 06:53 PM
low VOLTAGE joeyschribar ZJ Grand Cherokee Forum 2 01-27-2006 07:05 PM
very low voltage, what do i do ? grey03svt ZJ Grand Cherokee Forum 6 10-27-2005 05:14 AM
