Voltage and Check Engine... ? - JeepForum.com
post #1 of 6 Old 01-14-2008, 02:04 PM Thread Starter
tripsandfalls
Hi. Haven't lurked in awhile
The last time I spent some time on this forum was before I did the infamous np242 swap. That all went well, but now I'm back with a slightly different problem.
Specs: '93 ZJ, 230k'ish km on the clock, I6, AW4, np242. No real mods, but the battery is a optima redtop which is about 6 months old.
Last night as I was coming back from a pretty epic weekend of skiing, I noticed the voltage drop from the usual ~14 to somewhere just over 9. Uh oh. She seemed to be running okay, so I turned off most of the electronics, and found a spot to pull over. Pulled 'er over, popped the hood, checked the battery connections (which have been problematic recently), retightened 'em, etc. Unfortunately, when I restarted 'er (started no problem), the voltage stayed extremely low (~9.5, with no real variation), and the Check Engine light came on.
Got home okay, but unfortunately, this was all pretty late last night, and I had to come in to work this morning, so I haven't been able to pull any codes, or have a closer look under the hood. Just wondering if anyone has had similar issues, and any recommendations?
Alternator? Something else electrical?
Hopefully it's not a career ending injury, because I'm not living at home right now, and have limited tools and work space.
Cheers,
- Mark
tripsandfalls is offline
post #2 of 6 Old 01-15-2008, 12:04 PM Thread Starter
tripsandfalls
No suggestions?
Codes tonight hopefully. Although, I'm thinking it'll probably just pull the code for "voltage drop". Heh.
post #3 of 6 Old 01-15-2008, 12:26 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Need codes - get the alternator and battery tested as well. I know here in the states, most of our chain parts stores do it for free.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 6 Old 01-15-2008, 01:03 PM
thebgkoolio
sounds like the alternator. i had mine do the same to me about a month an a half ago. also check the fuses for the altenator. i had the alternator go out slowly an it blew 1 of the fuses but was still able to drive around 9 volts for a day or so then the the alternator went out completely taking the other fuse out. but after a new alternator and 2 new fuses its workin fine, but it does sound like the alternator is going out.
13 JKU -33's, afe exhaust, more to come
Sold: 94 zj -3.5" on 31's, bunch of other mods.
thebgkoolio is offline
post #5 of 6 Old 01-16-2008, 12:32 PM Thread Starter
tripsandfalls
Codes 12 and 41.
12 is battery disco in last 50 cycles, which is fine.
41 is charging system problem, voltage below 11.something.
I cleaned the battery terminals, and retightened the clamps. Seems to have worked for now. I think it's time for some new terminal clamps, the stock ones are really having a hard time gripping the optima redtop terminals.
Might spring for a new alternator anyways. The original one is about due to leave me stranded somewhere.
post #6 of 6 Old 01-16-2008, 01:08 PM
FPKites
ZJjazzyJim
FPKites's Avatar
PepBoys in the states has universal battery clamps for $2USD. Cut off the stock, strip it back a bit, tighten down the clips on the universals. Piece of cake.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Can someone do me a favor? Check voltage at a connector in 97/98 ZJ jeep_zj98 ZJ Grand Cherokee Forum 3 10-24-2009 02:43 PM
low voltage and check engine light alexofc69 ZJ Grand Cherokee Forum 5 06-19-2007 11:01 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
