Volt meter drops when put in rev. gear - JeepForum.com
post #1 of 11 Old 07-14-2010, 03:18 PM Thread Starter
my2monkeys
1989 XJ Cherokee
95 4.0 42re np249;
When I put gear selector in reverse the volt/ammeter swings down to the low end of scale.
Put it in nuetral or drive or park it shoots back up to 13-14 volt range.
Weird, anybody seen this before?
wifes 95zj 4.0 42re np249 201,000mi
mine 89 xj 4.0 aw4 np242 445,000mi
nephews 98 zj laredo 4.0 2WD 213690mi
my2monkeys is offline
post #2 of 11 Old 07-14-2010, 03:28 PM
freakinheep89
does the idle speed drop significantly when you put it in reverse?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 11 Old 07-14-2010, 03:32 PM
Mighty Thor
Jeez, how many amps you running through your back-up lights? You should probably be able to light up an airfield with that much lighting.
Is that supposed to look like that?
Mighty Thor is offline
post #4 of 11 Old 07-14-2010, 03:48 PM Thread Starter
my2monkeys
1989 XJ Cherokee
No significate idle speed drop from park to reverse. The same amount of drop when put into drive from nuetral, and ammeter doesnt drop when I go between those positions.
The GC is totally stock so no beefy Hella type reverse lights sucking up all the volts lol.
Thanks for the replies, I'm gonna go out and check it out. I'll post up in a few.
post #5 of 11 Old 07-14-2010, 03:49 PM
freakinheep89
there is no way the reverse lights can draw that much power unless theres some massive short to ground in the reverse light circuit.
TJ-
post #6 of 11 Old 07-14-2010, 04:45 PM
Mighty Thor
I kind of hope he knew I was kidding. does make you wonder about a short though. If not the lights themselves maybe in a trailer connector or something similar.
post #7 of 11 Old 07-14-2010, 04:56 PM
newfieZJ
test your battery
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 11 Old 07-14-2010, 07:19 PM
ZeeJay1997
i would suspect the park/neutral switch
ZeeJay1997 is offline
post #9 of 11 Old 07-14-2010, 07:39 PM
freakinheep89
i know you were messin with him lol, but yea if he has a trailer harness and the wires are frayed and touching the frame that could be your short
TJ-
post #10 of 11 Old 07-15-2010, 12:22 AM Thread Starter
my2monkeys
1989 XJ Cherokee
OK, so after looking at the reverse lights I saw they were real dim. Removed tail lite, took out left rev. lite bulb, other bulb went bright and gauge didn't move. Put old bulb back in and now everythings fine.
I guess the connection was bad or something,go figure.
You know that damn VIC with all its bull probably played a part, I don't know.
thanks guys,now on to the new squeaky pulley track down.
post #11 of 11 Old 07-15-2010, 06:37 PM
freakinheep89
its never that easy. something might be frayed somewhere, i would remove the taillight housing and see if the connectors are worn and fix if necessary. takes 10min and a safe way to confirm you dont have a short.
TJ-
zj , wj , voltmeter , drop , reverse gear , reverse , normal
Tach Jumps & feels like drops out of gear Airborne Lee ZJ Grand Cherokee Forum 26 07-05-2014 10:41 PM
Volt amp gauge drops lib88stang ZJ Grand Cherokee Forum 10 03-07-2010 10:49 PM
Speedo drops to zero davidt50 ZJ Grand Cherokee Forum 5 04-15-2008 09:25 PM
idle drops off way low jeep946 ZJ Grand Cherokee Forum 8 09-11-2006 08:45 PM
RPM Drops NYR99 ZJ Grand Cherokee Forum 2 03-25-2005 01:52 PM
