Is that voice normal in back differential - JeepForum.com
post #1 of 2 Old 11-26-2001, 05:53 AM Thread Starter
desert lover
I HEARD LITTLE VOICE COMMING OUT FROM DIFFERENTIAL AND MY FRIEND WHO USE WRANGLER SAYS ITS NORMAL IN ALL JEEP CARS
desert lover is offline
post #2 of 2 Old 11-26-2001, 01:04 PM
horatio102
The car should not be talking to you, unless you've got an exhaust leak and it's entering the cabin.
But if you've got a limited slip rear diff you might hear it making some noise at times.
My Grand Cherokee had transfer case whine on the freeway. The dealership replaced the driveshaft with a nickle(?)-plated one that was supposed to reduce noise.
horatio102 is offline
Check Battery, Voltmeter drops to zero than back to normal apexfactor ZJ Grand Cherokee Forum 25 12-23-2008 04:14 PM
Help please getting my hood back to normal shape! speedbird1229 ZJ Grand Cherokee Forum 13 03-10-2008 09:14 PM
Normal to have some back and forth movement in control arms ? jeepunlimited ZJ Grand Cherokee Forum 14 10-17-2007 09:52 AM
Getting my speedo back to normal? 04WJfreedom ZJ Grand Cherokee Forum 14 05-24-2007 04:24 PM
Low alt. voltage, threw CEL code 41, then back to normal ... ?? lawdogg ZJ Grand Cherokee Forum 10 01-05-2007 12:16 PM
