viscous coupler???? - JeepForum.com
post #1 of 8 Old 03-19-2002, 06:33 PM Thread Starter
brokengc
viscous coupler????
Got a problem with turning at low speeds. The steering binds up and lunges. Had it before and a vc repaired it. Same symptoms and they said it could be an axle joint. does this sound possible. If so how difficult is the repair and what does it all cost.
brokengc is offline
post #2 of 8 Old 03-21-2002, 02:09 PM
Beerman
Well if it's the vc and you wheel the jeep it would be a good idea to swap the t-case and put a 242 case in.
My buddy had his vc replaced and cost him around 1,100 bucks about the same for a rebuilt 242 that you can bolt right up.
Take a look at Transfercases.com
93 Grandcherokee limited V8 with lockers,lift,winch and other things
Beerman is offline
post #3 of 8 Old 09-26-2014, 05:45 AM
nectoxicdragon
its not the VC its the half shafts. AKA cv joints, your VC repair only hid the issue due to a smoother power transfer. they are not rebuildable, and are sold as side specific assemblies. make sure you pick up a set of spline sockets, (don't recall if its metric or sae but they are relatively inexpensive at harbor freight) if you intend to do it yourself, as well as a couple cans of brake cleaner and PB Blaster, the brake cleaner to degrease the bolts so the Blaster can penetrate. I don't recommend a torch if at all possible, unless you have a good oxy acetylene with a fine tip, due to the area you will be working. it can be a bit tight and you don't want to light up any grease from the rod ends...
The irony is YOU cant rebuild them, but you can buy rebuilt units... if you can figure that out let me know ( I know, special tooling required, but Ive seen this on parts that DONT require special tooling like some starters and alternators... profiteering at its finest)
nectoxicdragon is offline
post #4 of 8 Old 09-26-2014, 05:53 AM
nectoxicdragon
don't know what year you have so assuming a 98 and using rock auto for parts cost only you are looking at from under 100 to about 300 for both depending on the manufacturer ( https://www.rockauto.com/)
post #5 of 8 Old 09-26-2014, 06:52 AM
sebian
I would hope that after 14 years the problem has been fixed
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #6 of 8 Old 09-26-2014, 07:03 AM
nectoxicdragon
so would I, AND I would have expected he would have at least posted what it was for people who use the net to help troubleshoot the problems they are having, but too many people are extremely lazy about that.
post #7 of 8 Old 09-26-2014, 10:09 AM
NTH
How old is the diff fluid? Have you replaced the front diff fluid and make sure it's the correct spec? My new to me '98 was binding bad, and new fluid corrected it.
____________________________
1998 Grand Cherokee Laredo 4x4 // 5.2L // D30/44RE/NP249/D44a //
NTH is offline
post #8 of 8 Old 09-26-2014, 09:47 PM
nectoxicdragon
double check that diff. If just changing fluid took care of the problem there is something else going on. The front diff needs to be either an open or on demand unit. only a limited slip would be directly affected by the fluid like that. So either someone put a limited slip in the front end which can create unsafe on road driving issues in many situations, or the backlash is set up wrong and this can lead to significant damage. I can go on about how it could also be due to rig gear bolts coming loose and getting chewed up leaving metal shaving in the gear lube, but you get the idea...
Viscous coupler HarleyTyson ZJ Grand Cherokee Forum 41 08-21-2014 08:32 AM
Viscous Coupler livestrong ZJ Grand Cherokee Forum 1 05-17-2007 10:23 AM
Viscous Coupler Mustang ZJ Grand Cherokee Forum 5 02-18-2005 11:03 AM
Viscous Coupler LimitedTime5.9 ZJ Grand Cherokee Forum 9 01-12-2005 11:48 AM
Viscous Coupler mdloops ZJ Grand Cherokee Forum 12 11-12-2004 11:16 AM
