VIOLENT shake, but doesn't sound like death wobble... Please help! - Page 2 - JeepForum.com
post #16 of 28 Old 01-25-2012, 10:21 AM Thread Starter
GenesisGirl
looks like bent tie rod to me... I don't even know what half of this stuff is...lol
GenesisGirl is offline
post #17 of 28 Old 01-25-2012, 10:50 AM
sebian
I don't see any parts that look bent. Just very well used. The swaybar bushings are done, the tie rod end looks like it has been dripping grease for a while, as does the trackbar.
IMO, without looking at the ball joints, or tie rod ends on the wheels, it is time to rebuild the front suspension at the least. If you have the 4.0L I6, get the V8 parts as a nice little upgrade from stock.
If you are good at internet shopping, you can find some nice deals out there. But, I would guesstimate at spending $400-$600 on parts to refresh the worn components.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #18 of 28 Old 01-25-2012, 10:59 AM
PolkaPower
www.rockauto.com search google for a discount code as well
PolkaPower is offline
post #19 of 28 Old 01-25-2012, 11:00 AM Thread Starter
GenesisGirl
eeekkk... lol
post #20 of 28 Old 01-25-2012, 11:05 AM
PolkaPower
You don't have to spend that much but if you replaced everything it would get into that range. I would replace the stabilizer bar bushings first because they are obviously worn. Next I would lay under the front end and have a trusted friend turn the wheel back and forth while the Jeep is running and look to see what tie rod ends move around while the wheels are turning. There shouldn't be any play in them. If you take it in for an alignment the shop should tell you what parts are bad before they do it. Otherwise it's a waste of money.
post #21 of 28 Old 02-02-2012, 12:14 AM Thread Starter
GenesisGirl
So, Just want to update everyone.
Death Wobble was correct!
I had a friend send me to a good mechanic who wouldn't play games with me. I told him what we talked about in this thread. He replaced the steering stabilizer pump, and tightened a bunch of loose bolts on the drivers side front end suspension. cost me $100.
I've driven her all over Miami, no Death Wobble!!! But I will need to replace the ball joints soon.
As for the RPM's and TV cable, I'm paranoid. My cat-convert is F-ed up and I need to replace it: solution, put new radio and speakers today...lol
Thanks for all of the help! I would have believed it was the transmission if it wasn't for you guys
post #22 of 28 Old 02-02-2012, 12:29 AM
KoreaZJ
1994 ZJ
Now you know!
KoreaZJ is offline
post #23 of 28 Old 02-02-2012, 01:42 AM Thread Starter
GenesisGirl
Wow, thanks. That's really helpful. I'm sure I will be referring to that in the future.
By any chance do you have some sort of diagram or link to show me how to re wire the entire speaker system?
that was today's project, have to get the stereo playing so i don't have to hear the cat.converter...lol
post #24 of 28 Old 02-02-2012, 01:45 AM
KoreaZJ
1994 ZJ
How about HERE
KoreaZJ is offline
post #25 of 28 Old 02-02-2012, 09:17 AM
justinspotanske
I had the same issue with my 93 gc . went through and did a lot of work and money . Still not fixed . I replaced the steering dampener and that did the trick . Over a year later still fine . look into that . Its a 30 dollar fix.
justinspotanske is offline
post #26 of 28 Old 02-02-2012, 11:06 AM Thread Starter
GenesisGirl
yea, the dampener is the pump? I think we replaced the same part...lol. Mine is fixed now
How about HERE
Thanks Korea, I guess all I had to do was ask! I'm gonna try it out today.
post #27 of 28 Old 02-02-2012, 11:07 AM Thread Starter
GenesisGirl
How about HERE
post #28 of 28 Old 06-17-2012, 10:00 PM
Steelo805
Seems like I had a similar problem with my 96 xj. Was going about 45 with the rpms at about 2. I then stepped on it and it down shifted to about 3 or 3.5 and i heard a loud noise and i got this violent shake. i pulled over to s stop and drove about another mile and a half without issue but not going faster than 45 and easing on the gas. Ive had death wobble before and this was much more violent and jarring. any suggestions?
Steelo805 is offline
death wobble , idle too high , intake manifold , shake , throttle valve cable
Does this sound like death wobble? Darman ZJ Grand Cherokee Forum 1 02-15-2011 02:26 PM
Violent Shake Ray1997 ZJ Grand Cherokee Forum 10 08-19-2010 10:14 PM
Violent Shake in front end after 2" body lift 1995ZJDudE ZJ Grand Cherokee Forum 16 08-14-2008 08:44 PM
Death Wobble DW Shake Rford ZJ Grand Cherokee Forum 51 04-17-2005 06:57 AM
Violent Shake sidneya ZJ Grand Cherokee Forum 3 03-31-2003 06:30 AM
