VIC Swap - JeepForum.com
post #1 of 11 Old 11-07-2005, 02:55 PM Thread Starter
-Joe-
-Joe-'s Avatar
VIC Swap
There was a post on if this could be done a little while ago.
Just a shot of the non-digital information center installed.
After removing the 6 screws holding the trim on.
Remove the 3 screws holding the VIC in. You can see the non-digital only has 1 harness plug in the back.
The digital has two and the second harness plug is tucked behind the other beneath the AC controls.
Digital vic installed.
Here you can see it working. Tells me I have a bad washer fluid sensor (Would make sense because I dont have one - I jumpered the sensor connector and it changed to a low fluid warning, so im guessing it uses resistance to measure this, i plan to dig a pot out and see if i can find the resistance to make it think its full) And a rear lamp failure (Theres been several posts about this one already)
Not sure if its a straight forward on other years, but it can be done.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #2 of 11 Old 11-07-2005, 03:08 PM
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
Good write up!
Eric
RAAB3485 is offline
post #3 of 11 Old 11-09-2005, 07:57 AM
jeepholic
jeepholic's Avatar
A Picture is worth a thousand words!
Here's a cheap one if any one wants to give it a try;
http://cgi.ebay.com/ebaymotors/Jeep-...13242640QQrdZ1
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #4 of 11 Old 11-09-2005, 09:15 AM
mailforjon
mailforjon's Avatar
2005 WK
so the second harness for the digital VIC is already wired in the laredo and just needs to be plugged in?
can you give us a little more info as to what wires you jumpered for the coolant sensor and if youve had time to figure out how to deal with the low coolant issue?
thakns. good write up!
mailforjon is offline
post #5 of 11 Old 11-09-2005, 11:10 AM
deiol
Yeah, does the Laredo have the 2 plugs and most of the sensors for the digital VIC? What year did the Grand start to feature the digital VIC? Thanks
deiol is offline
post #6 of 11 Old 07-02-2013, 03:07 PM
Yoda95
Bump, pics gone bad, unanswered q's.
Yoda95 is offline
post #7 of 11 Old 07-02-2013, 03:48 PM
AVR2
The ZJ had the "digital VIC" from the beginning. Strictly speaking the VIC is just called the VIC; the much more basic display unit that was stock in the Laredo is called the GDM (Graphic Display Module).
93-95 VICs use two harness plugs, 96-98 VICs use one plug.
AVR2 is offline
post #8 of 11 Old 07-02-2013, 07:15 PM
leftfield6
Where are my damn keys?
leftfield6's Avatar
Not all JGCs had the plug in the dash though. My former ZJ, a 1998 Laredo, did NOT have the connector or harness waiting in the dash for the VIC
Jeepless for now, probably not for long
(former)
98 Grand Cherokee Limited 5.9
98 Grand Cherokee Laredo
77 CJ-5
75 CJ-5
leftfield6 is offline
post #9 of 11 Old 07-02-2013, 10:22 PM
coltman151
My 95 Laredo does for a reference point.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #10 of 11 Old 07-04-2013, 04:49 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
My 1998 laredo had the plug,minus some needed wiring. I overlooked it a couple of times because it was wrapped up in some gooey tape.
Originally Posted by HighLonesome
coralman is offline
post #11 of 11 Old 07-04-2013, 04:54 AM
leftfield6
leftfield6's Avatar
Just as a point of reference, my 98 ZJ that did not have the VIC plugs was a Canadian Model. Maybe that makes a difference.
(former)
77 CJ-5
75 CJ-5
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 07:44 PM
93 zj 5.9 swap lx2gt ZJ Grand Cherokee Forum 4 03-23-2009 11:42 AM
91 -97 Tcase Swap or motor swap ezrider327 ZJ Grand Cherokee Forum 6 05-12-2008 12:47 PM
AX-15 swap? JeepManZJ ZJ Grand Cherokee Forum 3 04-09-2006 09:25 AM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 06:28 PM
