VIC fuse blowing - JeepForum.com
post #1 of 5 Old 04-11-2013, 08:29 AM Thread Starter
davidmatlack
VIC fuse blowing
96 gcl 5.2
Fuse 6 blew yesterday. VIC, Overhead VIC and turn signals out. Replaced fuse- blew in about 1 minute. Removed flasher relay still blew. Jeep is original to me with no mods.
Note- It only happens when I move the shifter to reverse while the Jeep is running.
Any idea's whats causing it?
Thanks
davidmatlack is offline
post #2 of 5 Old 04-12-2013, 07:28 PM
KoreaZJ
1994 ZJ
Check for a short to GND.
  1. Neutral Safety Switch (NSS) may be shorted. Check switch with connector removed. Center pin should be grounded only while in PARK or NEUTRAL. Outer pins should have continuity only in REVERSE, never shorted to ground.
  2. Neutral Safety Switch wiring may be shorted. Check for damaged/shorted wires at/near NSS.
  3. Reverse lamps/wiring may be shorted. Check bulbs, sockets, wiring, etc.
  4. Auto Day/Night mirror may be shorted. Unplug it.
KoreaZJ is offline
post #3 of 5 Old 04-13-2013, 03:23 PM Thread Starter
davidmatlack
Spoke with jeep dealer who have been really good to my jeep for special problems. They are getting it next week. Initial thought is the PRND relay is bad. I guess this is on the side of the tranny. Does this make sense? I also replaced all the bulbs in the tail lights. One was blown but it was not a backup light. I'll pull the lights again to see if any of the new ones are blown.
Thanks for taking a shot at it
post #4 of 5 Old 04-14-2013, 02:27 AM
KoreaZJ
1994 ZJ
No relays on the side of the tranny. That's where the NSS is located, left side.
Location shown in diagram, inexpensive part, easy to replace.
KoreaZJ is offline
post #5 of 5 Old 05-05-2013, 01:24 PM Thread Starter
davidmatlack
Found Problem
A wire for the backup rear light left side had chaffed against metal.
Remove spare tire
open plastic access plate
find and repair wire.
Done!
