VIC engine symbol? - Page 2 - JeepForum.com
 1Likes
post #16 of 19 Old 09-20-2013, 09:17 AM
Aceladriver
Good tips on the VIC fix ^
Originally Posted by e46fanatic View Post
I just bought a ZJ a few weeks ago and I have a question about the VIC. It said my coolant temp sensor was bad, but I replaced the sensor and it went away. ?
VIC warnings are only for the level in the reservoir - but you already figured that out I guess
Originally Posted by zjosh93 View Post
The engine also lights up for low oil if you have the oil level sensor but it also usually says "Engine Oil Low" or "Check Engine Oil" or something like that. ......
Pretty sure 93 is the only year with the oil level sensor. I think it went away for 94 or 95
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #17 of 19 Old 05-23-2016, 07:10 AM
MikeiVan
97 ZJ VIC and Cluster Issues
All, Recently bought a 97 grand Cherokee for my son, 79000 miles. We see a lot of the same issues with flashing VIC, engine coolant and washer fluid indicators on the VIC even though they are full. So, when people say bad solder joints, are we talking bad solder joints in the connector at the end sensor, or in the VIC?
Also, we have a deal where we will be driving down the road, and every gauge in the cluster drops to zero. We drive like that with no gauges for a few minutes, then everything comes to life, all dummy light s flash as if you just turned the ignition on, and it goes back to normal. Any ideas on this one> Other than the intermittent coolant and washer level indicators, no other faults or lights. Thanks in advance!
MikeiVan is offline
post #18 of 19 Old 05-23-2016, 03:50 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes, solder joints inside the VIC.
Cluster issues could be confusion from a dying VIC on the CCD bus or just a drop in power. Does the overhead trip computer die when the cluster does?
kg6mov is offline
post #19 of 19 Old 06-08-2016, 02:29 PM
MikeiVan
Thanks,I guess we didn't notice what the overhead was doing, will need to watch for that.
MikeiVan is offline
