-   -   VIC engine symbol? (http://www.jeepforum.com/forum/f13/vic-engine-symbol-1587241/)
e46fanatic 09-15-2013 03:11 AM
VIC engine symbol?
I just bought a ZJ a few weeks ago and I have a question about the VIC. It said my coolant temp sensor was bad, but I replaced the sensor and it went away. Now the only thing showing on the VIC is a flashing red square in the engine compartment. The date and time flash along with it but the VIC does not display any other warnings. I hooked up my code reader and there are no codes showing. I want to know what would trigger the red square to light up without showing any additional warnings or codes. Or is this just one of those bad soldering jobs that I've been reading about?
AnotherRedZj 09-15-2013 07:34 AM
It's gonna blow!
Jk. Solder it if you like.....or Jus get rid of it. Mine died, no more beeping or flashing! Wouldn't have it any other way!
xcaliber81 09-15-2013 10:52 AM
Its just reminding you the engine is in its proper location. you know like X marks the spot lol. Heres what stumps me though whats up with the flashing window on the front.
Mickey_D 09-15-2013 11:20 AM
248 Attachment(s)
The flashing engine is for the low coolant. The flashing windshield is low washer fluid.
Both indicators of the bad solder joints.
I like having my VIC operational. It told me last week that my trailer wiring was FUBAR. As soon as I plugged in my trailer and stepped on the brakes with the turn signals on, the VIC started flashing telling me I had a rear lamp failure. It's also handy for letting me know I'm running low on washer fluid before I actually run out. Also very handy that the VIC tells me I have a brake light out before a cop does...
coralman 09-15-2013 02:37 PM
Main reason I have mine, I never check the bulbs, but the troopers do.
AnotherRedZj 09-15-2013 02:49 PM
Probly a good enough reason. Mine is still in there,Jus don't work. One day I may get a soldering iron....we'll see.
JeepNicholson 09-15-2013 03:09 PM
Irons are cheap and very very very useful for a menagerie of tasks!
e46fanatic 09-17-2013 12:57 AM
I know a lot of people here take them out, but I like knowing when there's a non-obvious problem with my vehicles so I can fix them before they cause other and bigger problems.
I filled the coolant and the light is still on, so I think it's safe to assume I need to do some solder work. Thanks for the info! By the way, the day after I posted this my "coolant sensor bad" warning came back.
zjosh93 09-17-2013 10:12 AM
The engine also lights up for low oil if you have the oil level sensor but it also usually says "Engine Oil Low" or "Check Engine Oil" or something like that.
My VIC has been perfect except for one bad capacitor that stopped it from working at all. Cost me less than a dollar at Frys and about half an hour to solder it in place. I do like that it tells me when my fluids are low or I have a bad bulb, or bad taillight wiring like it did a month ago.
My little circuit board soldering pencil came from Sears for like $20 I think and came with a little roll of solder. Not bad for a working VIC, swapping out caps in the PCM, etc.
Jeeples 09-17-2013 10:38 AM
While you're at it check your headlight/interior light switch as well, since you have to pull the lower trim piece off the dash to get the EVIC out, it's only a couple more screws to pull the headlight switch.
e46fanatic 09-18-2013 04:38 AM
Check it for what? More bad connections? Sorry, I'm new to the Jeep world.
AnotherRedZj 09-18-2013 06:49 AM
Bad solder joints
Do your dash lights flicker, or maybe Jus not adjust? Same issue
e46fanatic 09-19-2013 06:55 AM
Originally Posted by AnotherRedZj (Post 16105505)
Bad solder joints
Oh, gotcha. Yeah, actually sometimes a couple of the gauge lights go out and come back later. Thanks for the heads up!
newfieZJ 09-19-2013 07:57 AM
VIC fix with pics
http://www.jeepforum.com/forum/f13/c...moval-1228233/
Headlight switch fix with pics
http://www.jeepforum.com/forum/f13/r...-heavy-702703/
Both great write ups and both used personally . They work :)
Those and more found here http://www.jeepforum.com/forum/f13/n...-list-1121998/
e46fanatic 09-20-2013 03:48 AM
Originally Posted by newfieZJ (Post 16137657)
VIC fix with pics
Wow, thank you! That is really helpful. I'll be doing this very soon.
The time now is 10:48 AM.
