vibs at 40mph+ - JeepForum.com
post #1 of 6 Old 01-05-2007, 08:27 PM Thread Starter
OFFCHAMBERXJ
vibs at 40mph+
well here it goes. i installed my re4.5" short arm. i test drove it and i was getting a vibe on accel that started at 40mph and sounded like a rumbel strip on the side of the highway. so i installed the t-case drop kit to see if it would help, and it didn't. it caused a decel vibe in the rear and i still had the first one. so i took the drop kit off and i am just dealing with the rumbel strip.
if anyone has recomendations it will help i dont want something to come flying off and half of the brand new lift gets ripped off
WHEN IN DOUBT THROTTLE OUT. DO IT RIGHT THE FIRST TIME, OR PAY THE PRICE TO DO IT AGAIN AND AGAIN
OFFCHAMBERXJ is offline
post #2 of 6 Old 01-05-2007, 08:28 PM
rrubio
rrubio's Avatar
Do you have a cv-style driveshaft upfront?Get your tires balanced then an anligment.
rrubio is offline
post #3 of 6 Old 01-05-2007, 08:30 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Adjustable control arms? Sounds like your pinion is pointed towards the ground.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 6 Old 01-05-2007, 08:33 PM Thread Starter
OFFCHAMBERXJ
just got it alligned yesterday,no cv drive shaft and it sounds like it is coming from the front, will rear end vibes sound like the front
post #5 of 6 Old 01-05-2007, 09:25 PM
JTim
JTim's Avatar
What you're describing sounds a lot like what I'm dealling with. I took mine in for an alignment and i think they adjusted the camber to stock specs which completely screwed things up. Take a look at the front axle. If the pinion is pointed even slightly towards the ground, it's wrong. I'd suggest shortening your LCA's and seeing if that helps.
04 WJ, 4.0L, 4" lift, JKS adj TB
JTim is offline
post #6 of 6 Old 01-06-2007, 03:26 PM
BradBurdett
i've taken mine in to get an alignment and the messed with my castor specs putting them back to stock and when i got home i had to set it back to 5 degrees because of my front drive shaft U-joints
1995 ZJ 4X4
command-trac (NP231) with SYE
K&N FIPK intake
RE 6.5in lift with 33X12.5 BFG MT and no Rear Sway bar
4.56 gears--axle swap soon
BradBurdett is offline
40mph feels like I'm going over small bumps.. BlueTJMCRT WK Grand Cherokee & XK Commander Forum 8 01-15-2011 10:10 AM
Front driveshaft vibrates bad at 35-40mph! Whitelimited99 ZJ Grand Cherokee Forum 11 10-17-2009 07:13 PM
30-40mph Shake...I don't think its DW. Smith Erick ZJ Grand Cherokee Forum 5 04-03-2009 11:10 PM
Slight Shudder around 40mph IMFLASH WK Grand Cherokee & XK Commander Forum 5 11-19-2006 06:10 PM
Sputtering while Driving at 40mph jeeplovr ZJ Grand Cherokee Forum 10 12-19-2005 06:45 AM
