Vibration when i let off gas at hiway speed. - JeepForum.com
post #1 of 11 Old 04-03-2009, 01:14 PM Thread Starter
dickensheets
This annoying vibration feels like its under my feet when I let off the gas at speed. Not present at slow speeds or accelerating. Just started.
99 WJ V8 247tc 115,000 miles.
What is it?
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #2 of 11 Old 04-03-2009, 01:19 PM
Eldoradoman
What is it?
Check your rear differential fluid level.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #3 of 11 Old 04-03-2009, 01:21 PM Thread Starter
dickensheets
ok.
With the 247tc can I pull the front shaft and road test?
post #4 of 11 Old 04-03-2009, 02:44 PM
skain8
skain8's Avatar
Check your u-joints on your front shaft. Centering assembly could also be worn, assuming you have the dc front shaft. At that many miles, and with your mild lift, they could be shot by now.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #5 of 11 Old 04-03-2009, 04:46 PM Thread Starter
dickensheets
I drove with the door open down the street and low and behold I heard a squeaking noise. Sounded like the rear drive line. So I crawled under and found play at the rear output of the TC. I think this means a worn bearing.
So how involved is this bearing job? Can it be done from the rear of the TC?
skain: I have the CV style front. It seems solid as of now with no noise or play.
post #6 of 11 Old 04-23-2009, 01:06 PM
mnjeepmale
Same problem here. Vibration at highway speeds on my ZJ. When I engage the 4wd in Full or Part time the vibration is even worse. Any suggestions? Way to tell if the u-joints needs replacing?
mnjeepmale is offline
post #7 of 11 Old 04-23-2009, 03:01 PM
04ColumbiaWJ
i know this probably isnt the whole problem but make sure your tires are balanced. that could help too if theirs off balanced
04ColumbiaWJ is offline
post #8 of 11 Old 04-23-2009, 07:24 PM Thread Starter
dickensheets
The noise is gone. It fixed itsself.
post #9 of 11 Old 04-24-2009, 04:18 PM
vansskaterfreek
i have this same problem with my 04 wj 4.7L 247 TC. it only happens at like 80 MPH and when i let off the gas. i havent really looked into it yet, and i also have the squeaking at 15-35 MPH too. i was shooting towards u-joints, but havent looking into it much.
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #10 of 11 Old 12-08-2009, 01:01 PM
dsnell10
i have a similar problem in my 96 zj limited 5.2 249tc with 193,xxx miles 4inch lift and KOR tracbar conv. . after any speed of 40mph or more when i let off the gas, i get a vibration. the vibe stops around 15mph. i just put new wheel bearings in the rear axle. and im thinking the transfercase is on its way out and its leaking fluid from the rear output. would the vibe be from a bad output bearing and seal, or could it be u-joints in the rear? it feels like the vibe is coming from right under my feet which is about where the tc is.. or maybe further up like in the front drivers wheel.
Any diagnosis? any solutions? anything is appreciated
Next mod is swapping a 242 in for the junk 249.
dsnell10 is offline
post #11 of 11 Old 12-16-2009, 08:29 AM
RobinsonFam1
click my profile and go to my recent thread, or search it....i had same problem in 98 5.2 with 242tc.
it could be a tc issue but not likely. if it only does it at decelleration its the pinion side of rear diff, bearing is gone...when i did mine my axles were pitted/worn to hell also. had to replace the entire rear end, axles and all.
get to yours quick before you go down the same road. gets expensive quick!
RobinsonFam1 is offline
High Speed Vibration 4.7/Quadradrive WJ ephjeeper ZJ Grand Cherokee Forum 8 01-24-2010 08:19 PM
Weird vibration at low speed/idle befumo ZJ Grand Cherokee Forum 0 06-03-2009 12:56 AM
Vibration and low pitched drone sound increasing with speed benstar10 ZJ Grand Cherokee Forum 3 09-24-2008 10:01 PM
Front end vibration at speed rickd. ZJ Grand Cherokee Forum 9 03-29-2006 04:16 PM
Vibration at highway speed?????? jlr69s ZJ Grand Cherokee Forum 4 03-15-2003 12:22 PM
