vibration rear end - JeepForum.com
post #1 of 5 Old 04-07-2009, 11:32 AM Thread Starter
am9010
vibration rear end
My jeep has a problem and i don't know if its a drive shaft or tranny issue. in drive (1st gear) when i accelerate semi to hard the whole rear end vibrates and shakes, i was able to see that my driveshaft was clearly slipping, so is that a u-joint issue? however on the flip side i can hammer it in reverse and it runs perfect. the reason why i ask if its tranny is because my tranny already slips and shifts some what rough.
am9010 is offline
post #2 of 5 Old 04-07-2009, 11:42 AM
doublejz
well you can easily put it in N (while its off) and yank the ebrake. Crawl under it and rotate the driveshaft back and forth and check for play in the u-joints.
04 WJ with some stuff -
doublejz is offline
post #3 of 5 Old 04-07-2009, 12:27 PM Thread Starter
am9010
Thanks, Yeah i planned on trying that when i get home today. Any other opinions? Could this possibly be a tranny issue?
am9010 is offline
post #4 of 5 Old 04-07-2009, 01:19 PM
jeepheller98
cant really see it being the tranny, try the U-joints first cause its cheap, you can do it you self with a vise and a couple sockets to press it out.. note you need a vise that opens really wide, i got the biggest one home depot had for $70
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #5 of 5 Old 04-08-2009, 03:07 AM
sandman
my moms wj has been kindof vibrating too. it sounds like a tire is rubbing, but its not, is that what your hearing? happens only on left turns for me. i would start with a fluid change, i honestly think in my case its a LSD issue.
1993 Jeep ZJ. 4.0
sandman is offline
Vibration, and noise from the rear... xj4play ZJ Grand Cherokee Forum 4 01-15-2009 11:02 AM
Rumble, vibration in rear end?? Gerald K4NHN ZJ Grand Cherokee Forum 2 12-02-2007 10:40 AM
Vibration in rear baddarryl ZJ Grand Cherokee Forum 5 11-24-2007 08:32 PM
vibration in the rear end JeePing21 ZJ Grand Cherokee Forum 6 10-15-2006 08:06 AM
Rear vibration problem... JamesEric ZJ Grand Cherokee Forum 2 09-29-2005 11:24 AM
