Vibration, Noise and Pulling!!! Some Intermittent ~ HELP?! - JeepForum.com
post #1 of 17 Old 08-13-2009, 07:21 PM Thread Starter
SouthSeaPirate
Original thread. May or may not be related...
After changing the tires Im almost pull and vibration free. Its a very slight constant pull to the driver side and an intermittent vibration.
Conditions for vibration; Starts at about 25MPH under normal acceleration, then stops when it shifts to the next gear. Then again at 45MPH until shift (and Im sure some in between). If I hold a steady speed and pull off the throttle just a hair I will also have a vibration. Its a small but decent effect, enough to rattle plastics inside...
Noise; a faint whiiir whiir whiir, stopping in between.
Conditions before tire change; driver side tire had about a 7inch long bubble/knot. Before I noticed it, I checked any play in the system (by grabbing and moving the wheels by hand) and found none. Only when both wheels are suspended do I have play (but that moves the whole system all the way to the steering wheel). Ive also noticed the rubber/bushings are quite worn - 201,000 miles. The passenger caliper has a slightly higher drag then the driver (but before you scream caliper, remember, it pulls to the driver not passenger).
I need to know what to check from here. I am by no means a mechanic but I dont need step by step instructions most of the time. So shoot off any ideas you might have. TIA
SouthSeaPirate is offline
post #2 of 17 Old 08-13-2009, 07:53 PM
jeep95xj
1995 XJ Cherokee
If it pulls with new tires the alignment was done wrong OR you have a problem in the front end. Ball joints, TRE, track bar, something along those lines. Vibration could be a driveshaft u-joint.
jeep95xj is offline
post #3 of 17 Old 08-13-2009, 08:20 PM Thread Starter
SouthSeaPirate
Ah ha Driveshaft! Ill replace the forward one (already replaced the rear one and it was toast) because Im sure Ive heard some squeeking.
post #4 of 17 Old 08-13-2009, 08:26 PM
jeep95xj
1995 XJ Cherokee
There ya go that may be all it is. Still have them check the alignment and front end. Pulling is not normal. Could also be play in your steering box. If you dont have a sloppy box you dont own a jeep lol.
jeep95xj is offline
post #5 of 17 Old 08-13-2009, 11:04 PM Thread Starter
SouthSeaPirate
Originally Posted by SouthSeaPirate View Post
Ah ha Driveshaft! Ill replace the forward u-joint (already replaced the rear u-joint and it was toast) because Im sure Ive heard some squeeking.
Fixed
Let hope The pulling really isn't enough to cause alarm. I just thought it might be related to the vibration issue, which is my main problem.
post #6 of 17 Old 08-13-2009, 11:24 PM
jeep95xj
1995 XJ Cherokee
Sweet hopefully your problems are gone.
jeep95xj is offline
post #7 of 17 Old 08-14-2009, 03:28 PM Thread Starter
SouthSeaPirate
OOPS I meant the post was fixed. Post number 3 made it as if I was going to replace the front driveshaft (I have 2 wheel). I was just correcting it to say u-joint. Anyway Ill be fixing it on Tuesday since its my only day off Roomy is picking up the new u-joint now
post #8 of 17 Old 08-14-2009, 08:13 PM
jeep95xj
1995 XJ Cherokee
ahh lol well keep us posted
jeep95xj is offline
post #9 of 17 Old 08-20-2009, 02:28 PM Thread Starter
SouthSeaPirate
^ The man! LOL yeah no more vibration.
But now coming to work I had one hell of a shimmy when I hit my brakes comeing down from 50MPH. And I mean it was a dangerous wobble!
Any ideas???
post #10 of 17 Old 08-20-2009, 08:29 PM
jeep95xj
1995 XJ Cherokee
Most likely you need new rotors and pads up front. Warped rotors. Leme know how it goes.
jeep95xj is offline
post #11 of 17 Old 08-20-2009, 09:07 PM Thread Starter
SouthSeaPirate
I should have mentioned it happened other times as well. Not just when braking; twice with brakeing and twice without. Rotor looks okay and wheels spin freely without drag. Pulls to the left, and only slightly more when braking. Left caliper and pads have already been replaced (caliper did drag a bit before replacement, smell pads - other side is only little drag). And if it were rotors, wouldnt it happen all the time. This has happened over, Id say, about 3000 miles.
post #12 of 17 Old 08-20-2009, 09:26 PM
jeep95xj
1995 XJ Cherokee
#1 you should always replace both sides or dont do it at all. #2 Your rotors are warped and you need an alignment. Buy new rotor, pads, replace the other caliper if it's holding up. After that you should be good.
jeep95xj is offline
post #13 of 17 Old 08-20-2009, 09:33 PM Thread Starter
SouthSeaPirate
Rotors and pads, got it
The drag, I mean, isnt even noticeable. I shouldnt even have mentioned it...
How do I get an alignment?
Everyone Ive ever spoke with whos gotten an alignment from a shop ended up worse... So I dont want to go to a tire shop.
post #14 of 17 Old 08-20-2009, 09:36 PM
WhiteOut
WhiteOut's Avatar
How many people have talked to and do they know what they are talking about?
Get the tires balanced and have a road force alignment
WhiteOut is offline
post #15 of 17 Old 08-20-2009, 09:41 PM
jeep95xj
1995 XJ Cherokee
If everyone says they have ended up worse dont you think there is a problem there? Are they all going to the same place? If you have a local offroad shop take your jeep to them. If not do your homework and go to someone local with a good reputation.
jeep95xj is offline
Squealing noise while in park. Intermittent. Primer_Apollo ZJ Grand Cherokee Forum 10 07-12-2015 01:23 PM
Intermittent Severe Vibration Jeep GC WK 5.7L mmain WK Grand Cherokee & XK Commander Forum 2 03-04-2013 01:17 PM
Intermittent cold air when heat is on, and dash noise WildFoxMedia ZJ Grand Cherokee Forum 15 12-31-2009 11:50 PM
intermittent overheating and pump noise? UNDERDAWG ZJ Grand Cherokee Forum 0 05-26-2009 09:30 PM
Intermittent rapid clunking noise 73Bird ZJ Grand Cherokee Forum 3 03-04-2004 05:40 AM
