vibration at highway speeds - JeepForum.com
post #1 of 5 Old 07-15-2014, 06:47 PM Thread Starter
derekroth91
Hello I drive a 98 Jeep grand Cherokee limited 5.2 l v8 with a 3 inch rough country lift kit. I can typically hear some sqeaks at typical city speeds but they are scattered. When getting up to 45 it starts to shake and does so more the faster you go. I can feel the shaking in the steering wheel and in the vehicle. Took it to get tires rotated and balanced and I'll test drive tomorrow to see if it helped. But my CV joint (I thinj) is shot and is clicking at slow turns. Would this be the culprit? If not what else could it be?
derekroth91 is offline
post #2 of 5 Old 07-15-2014, 09:15 PM
mig1289
Dui you have adjustable track bars? Have you replaced control arms and tie rod ends?
2wd zj...
mig1289 is offline
post #3 of 5 Old 07-15-2014, 11:10 PM Thread Starter
derekroth91
I doubt it. I believe tie rod ends and track bar was replaced 1000 miles before I bought it which was 3 weeks ago and it was anever taken off road. So I doubt it has an adjustable track bar. Why do you ask? By that I mean what could/would that have to do with it?
post #4 of 5 Old 07-16-2014, 12:35 AM
mig1289
You might want to torque down all the parts in the front end, does not hurt to double check to make sure it's all tight there
2wd zj...
mig1289 is offline
post #5 of 5 Old 07-16-2014, 05:13 PM Thread Starter
derekroth91
I couldn't find anything that was lose but I find out my e brake is non existent and I need rear brakes and rotors. Could this contribute to the squeak or shake?
