Vibration at higher speeds.. 50mph+ - JeepForum.com
post #1 of 5 Old 01-23-2013, 01:36 PM Thread Starter
Kanola
Got a 96 grand Cherokee 5.2 v8 full time 4wd I just swapped out the front axle from a CV style yoke to a U joint yoke style axle. I drove it around for awhile without the front driveshaft (for different reasons) and it had no vibration problems so I dont think it's my tires being unbalanced.. So I picked a U joint style driveshaft off a junkyard zj and put that on the new front axle and now when I get it on the freeway the jeep begins to vibrate randomly and it comes and goes often.. It seems it vibrates more whenever I let off the gas and begin to coast at high speeds..
Please let me know any ideas might help thank you!!
Kanola is offline
post #2 of 5 Old 01-23-2013, 01:47 PM
PolkaPower
Did you have the new shaft balanced and check the U joints?
PolkaPower is offline
post #3 of 5 Old 01-23-2013, 10:22 PM Thread Starter
Kanola
I'm not sure how to check or test the U joints.. And scince I pulled the driveshaft off another jeep I figured it would be ok, but maybe that's not true?
Kanola is offline
post #4 of 5 Old 01-24-2013, 02:55 AM
PolkaPower
It could be worn out, unbalanced, or bent.
post #5 of 5 Old 09-23-2013, 08:46 PM
tevisesplin
check the torque of the t case front output shaft yoke. Specs are 90 - 130. Mine would vibrate starting at 65. tightened the yoke nut and it seems to have stoped
tevisesplin is offline
