Vibration after alignment - JeepForum.com
post #1 of 3 Old 07-11-2011, 04:48 AM Thread Starter
BlueDevil
So I had my front CA bushings replaced (all of them), and I was advised to do the alignment, which I did. It was OK, aside from the steering wheel that was a bit to the driver's side when going straight, so the shop adjusted that. All well, except that I get vibrations on 80 and 120 kmh (at 50 and at 75 MPH), which I know are said to be the speeds where vibrations will be felt by the driver (something about vibrations amplyfiing at those speeds). Whatever. I want it fixed, of course, although it's not some serious vibrations - but I feel them.
So what do I do? Get alignment again? Or try to see if tires are balanced first (though balanced or not, they did not vibrate before alignment & CA bushings)
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #2 of 3 Old 07-11-2011, 06:27 AM
tonymartin
maybe the shop didn't tighten the control arm bolts fully? Could also be that, other bushings are on the way out such as the track bar, sway bar/links, or the tie rod end joints. Always good to get a balance when you get an alignment though, just to be sure!
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #3 of 3 Old 07-11-2011, 06:34 AM
speedbucket
check your front pinion angle after the new bushings, sounds like the pinion u joint giving you vibes, slight angle changes can do this on old worn or slightly worn u joints
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
vibration when decelerating after tie rod end replacement and alignment swataz ZJ Grand Cherokee Forum 6 06-07-2013 01:24 PM
What the Alignment? Yardman Harry ZJ Grand Cherokee Forum 1 09-19-2007 12:23 PM
Alignment! JBN311 ZJ Grand Cherokee Forum 13 09-10-2007 07:28 PM
Alignment CrawfishStu ZJ Grand Cherokee Forum 2 05-16-2006 01:11 PM
Self Alignment Wiley ZJ Grand Cherokee Forum 14 02-11-2006 05:42 PM
