vibration at 65-70? - Page 3 - JeepForum.com
post #31 of 48 Old 04-12-2011, 08:48 PM
Candymancan
Well my 5.9 did have a bad engine mount, the place i bought it from replaced both mounts. How would i check the transmission mount ?
Candymancan is offline
post #32 of 48 Old 04-13-2011, 12:10 AM
Pugulis
I've had the same problem. Mine came at 55 then went away until 70 then it came back until 75, then it was gone again. I put new tires on and for the most part it's gone away. I'm thinking there could be a couple of causes for this. One the steering stabilizer (in conjunction with out of balance tires). My idea goes like this; You've got out of balance tires that start to wobble at high speeds. This causes the stabilizer to become worn out, but not totally shot. If you just put another set of tires on, without being balanced, they are going to be slightly out of balance, causing the problem to continue. So just putting tires on from another vehicle won't fix the problem. And you think it can't be the tires. But it probably still is, along with the stabilizer.
Another thing to consider (and this also goes with the stabilizer being bad) Most of our larger, even stock, tire sizes don't meet UTQGS (Uniform Tire Quality Grade Standards). Basically, truck tires don't meet the same standards as car tires. So even if you've had your tires "high speed" balanced, this may go over the 60mph speed where the wobble exists.
So for me, the next thing I do is replace the stabilizer.
Pugulis is offline
post #33 of 48 Old 04-13-2011, 05:08 AM
StidgeInTN
Get under it. The Tranny mount is on top of the cross member, under the tranny. Should be circular. If it's solid, should be good, if you can see thru it = replace it.
StidgeInTN is offline
post #34 of 48 Old 04-13-2011, 08:21 AM Thread Starter
97zjdriver
How hard is it to replace a pinon bering? And thanks for the replys
Sent from my Droid using JeepForum
97zjdriver is offline
post #35 of 48 Old 04-13-2011, 03:57 PM
StidgeInTN
I need to correct my error. i.e. Lack of knowledge. Just got my new Tranny mount in the mail, it's not solid like it looked in the picture or like a motor mount. So back to the question of how do you know your tranny mount has gone south. IDK ?
post #36 of 48 Old 04-13-2011, 04:06 PM
speedbucket
push up on the transfer case, i could move mine vertically quite a bit.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #37 of 48 Old 04-13-2011, 04:07 PM
Candymancan
edit: didnt see your 2nd post
post #38 of 48 Old 04-13-2011, 04:37 PM
StidgeInTN
I just posted it, and 2nd, i wasn't sure if the 5.9 has the same Tranny mount as my 4.0. I'm looking at it this way, it sure won't hurt to change it and i'll learn something new.
post #39 of 48 Old 04-13-2011, 04:37 PM
StidgeInTN
And was that Tranny mount good? Or baaaaaaad?
post #40 of 48 Old 04-13-2011, 04:41 PM
speedbucket
bad, give me a sec and ill post a pick of the old one
post #41 of 48 Old 04-13-2011, 04:48 PM
StidgeInTN
Here's a pic of the new one. When i first pulled it out of the box i thought i got crap. Closer inspection showed it's made that way.
post #42 of 48 Old 04-13-2011, 05:19 PM
speedbucket
bad one.
with load on it the center was all the way down on the ring
post #43 of 48 Old 04-13-2011, 05:41 PM
StidgeInTN
^^ yep, sitting on the rim. That's about where mine's at.
post #44 of 48 Old 04-17-2011, 05:21 AM
StidgeInTN
Wanted to update everyone on the Tranny mount. I could move the transfer case up and down a little, but it was really hard to tell it was bad...until i swapped them. I couldn't get a socket on the nut or bolt on the old one, so i had to take the crossmember off. When tightening the new one, with crossmember back in place and weight on mount, i could easily get to the bolt of the tranny mount. So i'd say this would be a good indication if your mount is worn out. In hindsight, i could've done this replacement without taking crossmember out by jacking up the Tranny some more, but wasn't sure how high I could go at the time. Took it for a test spin around town and, maybe it's just in my head, but it felt alot better. I didn't get up to 65-70 yet to see if it helped with vibes yet but will test that today or tomorrow.
post #45 of 48 Old 04-17-2011, 03:47 PM
StidgeInTN
Vibe is still there, but i've also got a "clunk" noise back there when i go over bumps. Can't feel anything lose, but prolly control
arm bushings. Don't want to buy bushing kit yet because i'm this close ( picture thumb and forefinger 1/4 " apart ) from getting the RC 3.5" lift and it comes with LCA's.
bad vibration at about 50-65 mph teg_ls ZJ Grand Cherokee Forum 24 03-01-2010 07:44 PM
vibration at 40 mph plus cherk ZJ Grand Cherokee Forum 10 11-29-2009 10:44 AM
Vibration??? topjoe ZJ Grand Cherokee Forum 2 09-20-2007 09:28 PM
Vibration Teds98Grand ZJ Grand Cherokee Forum 19 06-06-2006 02:28 PM
Vibration when in 4WD-FT jrdicker ZJ Grand Cherokee Forum 3 10-09-2004 07:52 PM
