vibration at 65-70? - JeepForum.com
post #1 of 48 Old 04-06-2011, 04:12 PM Thread Starter
97zjdriver
vibration at 65-70?
hi i have a 97 jeep zj 4 liter 6 cylinder. im new and what to mybe find out what this noise is. my grand parents had this jeep a year before i did and i have had it for about 5 months. the noise is when you hit about 60-65 and goes intill about 70 then tapers off. i did put a 3 inch bb lift in it but it was making the noise before just for reference. i just put new rear drive shaft u-joints on and still makes the nosie. my dad is driving it about 3 hours a day and is geating sick of the noise. and if its something that needs to be done it would be helpful to know before i go to north carolina this week end. thanks for reading and would like some advice.
97zjdriver is offline
post #2 of 48 Old 04-06-2011, 05:55 PM Thread Starter
97zjdriver
anyone anything?
post #3 of 48 Old 04-06-2011, 06:46 PM
freakinheep89
the tires are probably out of balance, thats usually the cause of high speed vibrations.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #4 of 48 Old 04-06-2011, 07:20 PM
KingtheZJ
x2
have you checked them?
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #5 of 48 Old 04-06-2011, 07:44 PM Thread Starter
97zjdriver
well i had the 31s balanced and the stocks are already balanced. the stock rims and tires are on it now but still the vibration. i was mybe thinking the yolk? or something in rear end? mybe tranny vibration?
post #6 of 48 Old 04-06-2011, 07:57 PM
ozzy_2_me
1994 ZJ
Just so some of you all out there no this.....the balancing of your tires will in no way cause a noise any any speed. i have a 94 and i am having a similiar issue with the noise at 60 - 70mph don't have the vibration though.
ozzy_2_me is offline
post #7 of 48 Old 04-06-2011, 08:14 PM Thread Starter
97zjdriver
it is not a horrible vibration, but i know its there like a buzzing. it stops around 70-75. i hope to find out the problem soon its a little anoyying
post #8 of 48 Old 04-06-2011, 09:02 PM
freakinheep89
I beg to differ. Out of balance tires can cause a vibration, even when they are only slightly out of balance they can still cause a noticeable vibe at certain speeds.
TJ-
post #9 of 48 Old 04-06-2011, 09:08 PM
Travisf90
i have the same problem i agree out of blanced tires will cause vibes but just got a new set put on and still does it i have a noise in my rear end at 50 and vibes start at 65 and just get worse the faster you go im thinking my problem is my drive shaft
Travisf90 is offline
post #10 of 48 Old 04-06-2011, 09:11 PM
freakinheep89
how do the u joints in the driveshaft look? also is there any fluid coming from the pinion seal of the rear axle? your pinion bearings may be going south. that caused bad vibes in my old D35. now the front's doing it too
TJ-
post #11 of 48 Old 04-06-2011, 09:38 PM
JS97ZJ
Check the front axle u-joints for play. Mine did similar at 60-70.
JS97ZJ is offline
post #12 of 48 Old 04-07-2011, 05:30 AM Thread Starter
97zjdriver
just did rear u-joints less then a week ago. and the noise was there for my grand parents before so its not a recent noise. its been there ever scine we have had it
post #13 of 48 Old 04-07-2011, 05:32 AM
Candymancan
My 5.9 has the same thing at 60-70mph. Its really bad at 70, but at 75+ its completetly gone. Altho the noise on mine is coming from the rear differential i suspect as its happening in the back in the back of the Jeep in the trunk at least so my ears tell me. At 70mph if i go over bumps on the freeway the rear end will make a rubbing noise like teeth on gears are touching eachother or something. Checked my u-joints and as much as i pull twist them i dont feal any play
I just havent gotten to getting it looked at by a shop yet, the money i had i spend on buying a new VC which i need to install and then get a 4 wheel alignment as 1 of my tires is wearing out on the outside vs the others. I have had the tires balenced tho and that didnt fix it
Candymancan is offline
post #14 of 48 Old 04-07-2011, 05:55 AM Thread Starter
97zjdriver
Ya that is just what mine is doing. Althogh I haven't really been looking for the location but as weird as it is it disappers at 75. I don't realy hear a grinding when lisening to it.
Sent from my Droid using JeepForum
post #15 of 48 Old 04-07-2011, 05:59 AM
Candymancan
Yep, so when im driving on the freeway i try to stay at either 63mph and just park myself behind a big rig on the far right lane and set cruise control on. Or if i have too because of the flow of traffic, i will try to get to 75mph. That way at 75mph all the rumbling noise is gone completetly, and at 65 or under the rumbling noise isnt AS loud its still there but not as teeth wrenching to where you think something is going to explode on itself.
I really hate tho when i have to keep my speed at 70 thats where its the worst.
I wonder why so many people have problems at the same speeds.
bad vibration at about 50-65 mph teg_ls ZJ Grand Cherokee Forum 24 03-01-2010 07:44 PM
vibration at 40 mph plus cherk ZJ Grand Cherokee Forum 10 11-29-2009 10:44 AM
Vibration??? topjoe ZJ Grand Cherokee Forum 2 09-20-2007 09:28 PM
Vibration Teds98Grand ZJ Grand Cherokee Forum 19 06-06-2006 02:28 PM
Vibration when in 4WD-FT jrdicker ZJ Grand Cherokee Forum 3 10-09-2004 07:52 PM
