Very weird problem after locking with keyless entry - JeepForum.com
post #1 of 15 Old 04-07-2009, 11:16 AM Thread Starter
ABerry
For the past few months in my WJ after I get out and lock the doors with the keyless entry (haven't ever used the physical key slot, I may try that) the dome lights don't turn off after locking... All doors lock fine, there are no doors open, and I have checked the dimmer switch... I have gotten use to it since the jeep cuts power after 5 minutes (I believe) which shuts all the lights off by design... If I needed the lights off that second I would just turn the dimmer to make sure no lights come on... the lights staying on after locking happens I believe about 75% of the time, sometimes it works. It was an annoyance I could live with until I realized my alarm isn't engaging when I lock. The flashing light doesn't come on at all... I did a search and found tons of info none of which matched my problem... anyone have any ideas? I am in a very high theft area and need to get this fixed, any suggestions where (other than the dealer who is 30 miles away)
IRO 3", BFG MT KM2 31's, MX-6's
University of Oregon ALUMNI GO DUCKS!
ABerry is offline
post #2 of 15 Old 04-07-2009, 11:23 AM Thread Starter
ABerry
I searched JU and found a little extra information on a problem not identical but around the same as mine... people mentioned the keyless fob could be out of sync, something wrong with the battery etc... going from that, I am curious as to what range you guys get with your keyless entry? Someone mentioned 50+ft ... sometimes I will be within 10 feet and nothing will happen but I believe the battery is pretty new
ABerry is offline
post #3 of 15 Old 04-07-2009, 11:59 AM
MuddyLuxury
MuddyLuxury's Avatar
they battery in the key fob isn't realvent in this issue as it is sending the lock command to the doors. I would look at the fuse for your alarm make sure its good. and the length of time the lights stay on is a function set in the overhead VIC center.
edit, you may want to look at each door and make sure the mechanism that reports its closed and turns off the light is good, but you can still set the alarm with the door open, i know i have done it.
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #4 of 15 Old 04-07-2009, 12:25 PM Thread Starter
ABerry
thanks for the help... while driving the overhead vic reports no doors open... i'll be the only one in the car... get out, and shut the door (making sure it is shut) and the problem still happens... but sometimes it works
the thing with the alarm I was mentioning is when the dome lights don't dim after locking the car the alarm won't flash at all... when the lights go off after locking the alarm will come on no issue... it's like my keyless is telling all of the doors to physically lock and thats it, nothing else (dome lights turn off and alarm activates)
ABerry is offline
post #5 of 15 Old 04-07-2009, 12:27 PM
dougy147
I would suggest the same. I had an issue in my Altima where the auto headlights were not turning off after the 60 second delay. Turns out the door switch on the drivers door was bad, so the car didn't know I had gotten out of it and it wasn't dark enough for me to notice the dome light hadn't come on. I know it's a different issue but I think the door switches play a role.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #6 of 15 Old 04-07-2009, 01:15 PM
Airbird
I had the same problem a few months ago with a 2004 Grand Cherokee Limited
It ended up being a wire in my driver side door, the wire was split right at the hinge were the wire ran from the door to the the dash.
All I did was spliced the wire back up
Anyways it looked as if the wire had alot of tension and the hinging of opening and closing the door split it.
I'll take a picture when I get out of the office
Airbird is offline
post #7 of 15 Old 04-07-2009, 01:39 PM Thread Starter
ABerry
hm I'll definitely check the wires out when I get back home... a picture would be great as well!
ABerry is offline
post #8 of 15 Old 04-07-2009, 01:49 PM
Airbird
I'm thinking your having the same problem as I did, check back later tonight and I'll have them pictures for you!
It seems to be a problem for the 2004, if you do a google search you'll find more info
heres a link to guy having the same problem
http://wiki.answers.com/Q/2004_Jeep_...ther_Any_ideas
Airbird is offline
post #9 of 15 Old 04-07-2009, 02:41 PM Thread Starter
ABerry
Well I found the problem lol...
any suggestions?
ABerry is offline
post #10 of 15 Old 04-07-2009, 04:26 PM
xJoshxx
2012 WK
Lol wow thats same thing thats starting to happen to me
The thing that broke off yours is Kinda broke on mine the part that attaches in the hinge is what is broke on mine makes a LOUD popping noise when i open the door.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #11 of 15 Old 04-07-2009, 05:28 PM
dougy147
Ha, mine is on it's way to looking like yours. Let us know how much fun that was to change.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
post #12 of 15 Old 04-07-2009, 11:28 PM
MuddyLuxury
that braket is easy as pie to remove, i take it off when i go doorless. just a question of how much the dealer is going to charge for the replacement part
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #13 of 15 Old 04-07-2009, 11:30 PM
xJoshxx
2012 WK
Well the thing thats attached to bracket is whats kinda broke on mine makes a loud POP when i open and shut it
Write up on how to fix this bad boy?
2011 WK2 ORA2 sold
xJoshxx is offline
post #14 of 15 Old 04-08-2009, 02:17 PM Thread Starter
ABerry
I'll try to get the part and do a small write up... sounds like it is maybe a defect if all of us are having problems... and my rig is a 2004!! There are two things in this world that come from hell... one is waking up from sleep before your body wants to, the other is buying parts from a jeep stealership... I spent 10 minutes at a stealer trying to describe the middle parking light bulb in the headlight housing that I needed to replace.. and after, i went home installed it to find out it wasn't even the right bulb
wish me luck
ABerry is offline
post #15 of 15 Old 04-08-2009, 05:53 PM
dougy147
wish me luck
What is wrong with these people? I called one about getting a new coolant bleed plug for the 4.7 ($3 part) and this guy tells me it's not available and I have to buy the $400 timing cover. Another stealer found it and didn't even charge me list for it. I ended up using something else anyway
You just disconnect it from the body though, right? To replace the whole thing, it looks like the door check has to go inside the door which means removing door panel, etc. My check is definatley going bad so I have to replace the whole deal eventually.
If mine had broken like that and I didn't have access to a welder, I would probably go to a JY and and get that piece by drilling out the rivet. Then just bolt it up, use a new rivet to attach with a washer on the bottom and you're good to go.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
GC Ltd 96, Keyless entry-Immobilizer Problem? BigDog635 ZJ Grand Cherokee Forum 0 07-03-2008 01:49 AM
Remote keyless entry - memory problem? dynamok ZJ Grand Cherokee Forum 18 10-28-2006 09:12 AM
Keyless entry Mr Q X ZJ Grand Cherokee Forum 2 07-19-2006 07:18 PM
2004 keyless entry problem robert0550 ZJ Grand Cherokee Forum 8 01-23-2006 04:40 PM
Keyless Entry Problem Part 2 CRCoatings ZJ Grand Cherokee Forum 8 12-03-2004 02:31 PM
