very sluggish and missing after longer drives! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > very sluggish and missing after longer drives!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 12-22-2009, 03:02 PM   #1
bmx_hb_guy
sooo it never has the problem unless i drive 30mins. plus but getting worse
after long drives it wants to get more an more sluggish untill it decides to start missing but only after about 30+ mins of driving.....and under heavy acceleration......sumtimes itll jump to 4000 rmps when i stomp it and jus contuisly miss till i let off the gas and it shifts...
new coil, cps, ecu, cap, rotor ,plugs , wired,.....wat else?
98gc 4.0....no codes~!
93 wrangler 2.5l, 2in lift shackels, 31's, eagle alloy 186,and a flowmaster 44
98 zj 4.0 straight 6, 4in f<r lift, adj. trak bars, rustys sway bar quik discos, skyjacker shocks, rancho steering stabalizer, 32x11.50 daytons, straight piped, 2 12" pioneers,
I DO ALL MY OWN WORK!
AND YES IM 17 BUT THIS JEEP AINT DADDYS MONEY!
bmx_hb_guy is offline   Reply With Quote
Unread 12-22-2009, 05:28 PM   #2
ratmonkey
R.I.P.
ratmonkey's Avatar
look to things that come into the loop when you're out of warm up mode.
start by unplugging your o2 sensor and driving around for a while, you'll get a code but it should tell you one thing or another.
ratmonkey is offline   Reply With Quote
Unread 12-22-2009, 06:11 PM   #3
bmx_hb_guy
took her for a ride without my o2 sensor hooked up and still messing up and still very sluggish to get up to speed
Unread 12-22-2009, 06:35 PM   #4
EisBlade
I, Soldier.
EisBlade's Avatar
Are the shifting points off, delayed, or not at all in the top gears? Rough idling? Won't go when you stomp on it and feels like it's sputtering? Reaching 4000 when stomping on the gas is not part of the diagnostics that count, but the shifting part is. How old is the TPS?
JT
LIFTs, TIREs, SPRINGs & GEARs:
WJ Spring Rate Chart. /// .Tire Size vs Lift. /// .Tire Size vs Gear Ratio. /// .WJ Noob Lift Chart
Driveshaft Angles & Pics of Rear Diff Pumpkins:
Correct Pinion Angles. /// .Correct Driveline Geometry 101. /// .Rear Differential Covers; What They Look Like
Death Wobble (DW): IRO 'Death Wobble Checklist'. /// .More DW Notes (from JK forum)
WJ Emergency Brake Reset Procedure: Click For PDF
WJ Headers: Doug Thorley Header pics for 4.0L 99-01 WJ's ($499)
Click here to view my sexy Jeep girl, and then watch her slay you.
Raunchy Racine
DISCLAIMER: Not responsible for men of weak character.
EisBlade is offline   Reply With Quote
Unread 12-23-2009, 05:46 AM   #5
Butters98TJ
When was the last tiime you changed the fuel filter? I've had issues with clogged fuel filters on several different cars and it sounds similiar to your situation. If that's the case your fuel pump would be working overtime and shortening it's life.
1998 Jeep Wrangler Sport loaded with TONS of extras!_
4 liter 6cyl, 5speed but thats just where it starts._
Full Borla stainless exhaust (header and cat back)
Rock-it intake with K&N air filter
Hi Capacity 3 core radiator
Steering box skid plate
Bullet proof bumpers FRONT AND REAR
4" Skyjacker Double flex lift
Currie anti-rock sway bar
33" Super Swamper Radials on AR767s
Butters98TJ is offline   Reply With Quote
Unread 12-23-2009, 06:47 AM   #6
bmx_hb_guy
iv recently (within 6 months) changed my tps.....
as for ideling sometimes its smooth as i think itll get and outher times its like its like a pulsing idel
also forgot to add sumtimes when im coming to a stop it will cause my rpms to drop off but they always make there way back up shortly?
and iv got a 98 gc with tells me its in the tank????....iv checked for an external fuel filter but none for me to find?.....also iv read that with an internal filter u cant do nothing about it cuz its part of the fuel pump???
sooo how would it be cleaned?
Unread 12-23-2009, 07:33 AM   #7
gbauer
I have a 99 WJ V-8. I had very similar problems. I did the following: 1) seafoamed it. 2) changed the plugs and (because I had a misfire code after 4 months of problems) changed two coil packs. 3) I had a faulty speed sensor on the transmission. 4) Changed the fuel filter. Seems to be fine now but time will tell...
The speed sensor and coil packs were the real culprits. I threw some other parts at it with no change (TPS, MAP) but they were probably due anyway.
gbauer is offline   Reply With Quote
Unread 12-23-2009, 11:28 AM   #8
bmx_hb_guy
its mising after a long drive but its always sluggish.....would the speed sensor cause a miss?
