Very rough idle - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Very rough idle
D.i.y. Ford 8.8 tj,xj,yjTrek Armor Seat Covers now at JeepHutJeep Restorations, Mild to Wild! CCOR
Unread 04-15-2012, 10:11 AM   #16
Bannerman53
I cant wiggle the injectors while it is running because it wont run. The only way to keep the engine going is to keep my foot on the gas pedal. It goes fine through all the rpms but once i take my foot of it just dies . If I rev it for 2-3 minutes it will idle correctly again, but I don't want to be doing that every morning.
Bannerman53 is offline   Reply With Quote
Unread 04-15-2012, 10:22 AM   #17
JasonStebbins
Sounds like it isn't getting enough fuel. Do you know when the fuel pump/filter was changed last?
Common ZJ problems and how to fix them :
http://www.jeepforum.com/forum/f13/c.../#post14369331
12 things to do when your ZJ stalls :
http://www.jeepforum.com/forum/f13/1...talls-1407423/
JasonStebbins is offline   Reply With Quote
Unread 04-15-2012, 10:26 AM   #18
Bannerman53
HAvent changed the fuel filter in a long time, if ever.
Unread 04-15-2012, 10:31 AM   #19
JasonStebbins
I would suggest swapping in a new fuel pump, but that's a pricey place to start
If it clears up somewhat after you hold the throttle, it seems like it's just not getting enough fuel at idle.
Unread 04-15-2012, 01:40 PM   #20
booked101
Maybe a dumb suggestion but you could try seafoam in your engine through the throttle body and see if that helps the idle problem.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline   Reply With Quote
fuel filter , iac , MAP sensor , rough idle , tps
