Vents will not switch. '04 WJ stuck on defrost. - JeepForum.com
post #1 of 25 Old 05-18-2009, 02:55 PM Thread Starter
zj+3
Whenever I turn the knob to switch the vents (from defrost to head and feet, feet, ect.) nothing happens. It just stays on defrost. Hot, cold, AC all work, I just cannot get the vents to put air out though the middle, and it is starting to get hot, so I need that AC blasting!
zj+3 is offline
post #2 of 25 Old 05-18-2009, 02:56 PM
iluvtruenos
Didn't we just answer this a few days ago?
Search!
iluvtruenos is offline
post #3 of 25 Old 05-18-2009, 05:38 PM
dmarko3
i just had that problem. does the cruise control not work too. on mine one of the vacume lines came off the engine. and it still comes off like once a week
dmarko3 is offline
post #4 of 25 Old 05-18-2009, 05:51 PM
Airbird
LOL i just came on here to ask just about the same question. My havoc vents only work for the windshield vent. Switching the vent to the different positions doesn't work. Is it a fuse?
Airbird is offline
post #5 of 25 Old 05-18-2009, 05:56 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you don't have the automatic climate control it's a vacuum line that's leaking. the line goes around the firewall to the cruise control and under the batt tray is where it terminates. it can have a leak anywhere along that length and you will loose cruise control and hvac function other than defrost.
ratmonkey is offline
post #6 of 25 Old 05-18-2009, 06:00 PM
Airbird
Wow thats really weird.. your right and it seems that we all have 2004 WJ's
Heres some pictures its right under the intake
Airbird is offline
post #7 of 25 Old 05-18-2009, 06:52 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
Originally Posted by Airbird View Post
My havoc vents only work for the windshield.
LOL that made my night, thank you
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #8 of 25 Old 05-18-2009, 07:00 PM
dmarko3
that's the same thing that keeps happening to mine. i keep putting it on and it keeps coming off
dmarko3 is offline
post #9 of 25 Old 05-18-2009, 07:25 PM
Airbird
Bah! HVAC* glad i made your night though.
Airbird is offline
post #10 of 25 Old 06-28-2009, 07:22 PM
jcloudr
But my cruis stll works....
I have a 2002 and the cruise is working, but all of the air comes out the defrost and floor... I can not make it change. I have looked for leaks and can't find any.
I NEED HELP !
Thanks!
jcloudr is offline
post #11 of 25 Old 06-28-2009, 08:21 PM
sparkeep
Ever heard of zipties? Just put one around the hose to tighten it on the stub.
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #12 of 25 Old 06-29-2009, 07:51 PM
salissc
2004 XJ Cherokee
Thanks for the posts, found my 2004 Grand Cherokee had the vacuum hose disconnected under the manifold.
salissc is offline
post #13 of 25 Old 06-30-2009, 03:36 PM
tazimafied
It's not just the '04. Mine had the same thing happen.
Because I felt like it!
tazimafied is offline
post #14 of 25 Old 06-30-2009, 03:56 PM
grandcherokee12
My '99 has done it once, but now that I know what it is, never seems to give me a problem.
grandcherokee12 is offline
post #15 of 25 Old 06-30-2009, 07:43 PM
allanmacaulay
So if all of mine are connected there....where should I look next? I've followed the lines and they all seem to be fine
1997 White TJ, 4.0 5 speed
Zone 3" Lift, JK Rubicon wheels & tires
RIP "Tonka" 2000 TJ
allanmacaulay is offline
No air coming from defrost vents D73 ZJ Grand Cherokee Forum 0 01-28-2010 07:09 AM
No Air from Defrost Vents D73 ZJ Grand Cherokee Forum 9 01-04-2010 12:11 PM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 08:45 PM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 12:52 PM
Air conditioner control switch stuck on defrost scout76 ZJ Grand Cherokee Forum 9 07-17-2004 06:03 PM
