vents/defrost door problem - JeepForum.com
post #1 of 3 Old 07-27-2011, 02:21 PM Thread Starter
pete315
When I turn on A/C, air comes out both vents and defrost. If I cruise on highway at a steady speed, sometimes air comes all out the vents but as soon as I step on the gas, it goes back to defrost. I know it's a vacuum problem. I know it has a check valve right by vacuum connection by rear of the 4.0 liter engine valve cover. I thought this check valve should prevent this problem. I then went under dash and see the vacuum valve that controls this door for vents/defrost. It appears that there is not enough vacuum to pull the plunger all the way in to get all vents. I removed the vacuum line and hooked up my hand held vacuum pump and plunger moves all the way in with no problem so I'm sure the vacuum plunger is working correctly. I checked as much of the vacuum lines as possible and I see no breaks. It's the green vacuum hose that controls this vacuum plunger. Why would I have low vacuum on this line? I swapped out another heater control head from another same year Jeep and it did the same thing.
pete315 is offline
post #2 of 3 Old 07-27-2011, 06:57 PM
MaintMech
Old and in the way
MaintMech's Avatar
There's a bunch of vacuum lines under the hood. Start with the "T" next to the firewall. There's a vacuum reservoir under the battery. Can be cracked.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 3 Old 07-28-2011, 10:23 AM Thread Starter
pete315
I check the T on the vacuum line. all looks good. I did not check that tank under the battery. I'll try that.
pete315 is offline
A/C will only blow through defrost vents TontoKowalski ZJ Grand Cherokee Forum 50 08-22-2016 10:03 AM
No air coming from defrost vents D73 ZJ Grand Cherokee Forum 0 01-28-2010 07:09 AM
No Air from Defrost Vents D73 ZJ Grand Cherokee Forum 9 01-04-2010 12:11 PM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 08:45 PM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 12:52 PM
