VC or rear diff? - JeepForum.com
post #1 of 3 Old 09-27-2002, 07:51 AM Thread Starter
bhnordness
VC or rear diff?
After placing a remanufactured t-case in my 95' GC, I still have the same popping or "wheel hopping". The problem is not as bad and is more like when my origional problem first began a year ago.
My theory is that they put a used VC in the new t-case. Could there be anything else in the driveline that would duplicate the chronic bad VC symptoms? Such as the rear differential?
The front end has been inspected inside and out and is fine. U-joints are all new and the control arms, ball joints etc... are all ok.
Thanks
bhnordness is offline
post #2 of 3 Old 09-29-2002, 06:59 PM
Randy Wells
I have had some crow hopping and popping on corners with all my Jeeps with lockers in the rear diff. It also has happened on the ones with limited slip rear differentials that use clutches when the clutch additive gets old.
Randy Wells is offline
post #3 of 3 Old 09-29-2002, 07:41 PM Thread Starter
bhnordness
Thanks. I've changed the fluid in the front and no change. The rear was a new idea after reading about how the system works. Maybe I'll change the rear as well...
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 12:53 PM
GC ZJ - Rear diff lanciaman ZJ Grand Cherokee Forum 1 10-29-2007 01:26 PM
Rear Diff dino61 ZJ Grand Cherokee Forum 8 09-16-2006 06:38 PM
97 zj rear diff dino61 ZJ Grand Cherokee Forum 7 09-08-2006 01:35 AM
Rear Diff lorrick ZJ Grand Cherokee Forum 5 04-11-2006 06:31 PM
