Various lift questions. - JeepForum.com
post #1 of 4 Old 02-11-2006, 12:10 PM Thread Starter
Derek33
Derek33's Avatar
Right now i'm running UC coils and kevins 2" spacers, without the stock isolator (loss of about .75 inches)
I was thinking of various methods of gettin my jeep higher, and i was thinking of a f>r but with UC coils i think its too high for stock arms and sway bars and such.
One thought of mine would be to install the stock spring spacers front and rear, and remove the BB and UC coils from the front and replace them with a 3.5" coil.
I would expect that to give me about 3" lift rear and 3.5" in the front, to get my jeep nice and level ( i hate rakes )
I guess what i need is a measurement from a stock jeep going from the center of the hub to the fender lip right above the hub, to get a comparison of how much lift i will get in the rear with my Uc coil, kevins spacer,and stock isolator.
I dont have access to many stock zjs, so if anyone has those measurments i would appreciate it. if it makes a difference this is on a 5.2.
Derek33 is offline
post #2 of 4 Old 02-11-2006, 07:01 PM
jmanimal
jmanimal's Avatar
In case no one replies in the meantime, keep a cheap tape measure in the Jeep and next time you are at Lowe's, the mall, wherever-measure a stocker there.
Now:2011 JKU
Gone:2001 TJ;1998 5.9 ZJ;1995 5.2 ZJ
matanzasjeepclub.com
jmanimal is offline
post #3 of 4 Old 02-11-2006, 10:39 PM Thread Starter
Derek33
Derek33's Avatar
ill do that.
any other opinions
Derek33 is offline
post #4 of 4 Old 02-12-2006, 12:34 AM
Decipticon
According to the FAQ,
" UC = Up Country
V8 UC Front Springs when moved to the rear: ~4" of lift
V8 Normal Front Springs when moved to the rear 3"~3.5" of lift"
I've read that stock control arms are good to around 3.5". If I were you I would use the regular springs. Put it all together, and if its uneven, measure it front and rear, and get the appropriate size spacer for the rear. You could even sell the 2" spacers and UC springs to pay for some the lift (or new control arms).
Jesus is coming. Look busy.
Decipticon is offline
2" Lift Questions.... Wheels and Tires Questions Too!!! torchd ZJ Grand Cherokee Forum 13 01-22-2010 03:35 PM
WJ Lift Questions... ruggedscotsman ZJ Grand Cherokee Forum 8 05-01-2009 04:22 PM
95 ZJ Lift questions. Black95ZJ ZJ Grand Cherokee Forum 13 03-07-2009 10:40 PM
More Lift Questions ryanp ZJ Grand Cherokee Forum 6 10-06-2006 10:43 PM
WJ lift questions again BradTE20 ZJ Grand Cherokee Forum 16 11-29-2005 08:23 AM
