#1 | |
Vari-Loc axels
how dependable are the vari lock axles are they just as good as a limited slip or better would it be better to change it to front and rear lockers
#2 |
Luck favors the prepared
Vari lock axles are limited slip diffs. However, it is nearly always better to change to lockers if you plan on doing any off roading, as LSD's have clutches that wear out over time, whereas lockers are permanent. The exception to this is the detroit tru trac LSD, as this is a mechanical limited slip, and does not have clutches that wear out.
#3 |
Actually, the Vari-lock LSD's are probably the best LSD ever included in a OEM jeep. Older Jeep LSD's (Trac-locks) used clutches to provide friction and stop wheel spin. The Vari-lock uses a gerotor and hydraulic pump to transfer torque between the two sides. While it isn't capable of the 100% lock-up that DC claimed, with stock size tires or 31's it works remarkably well.
The downsides are that it still uses a system which can wearout and replacement parts are expensive. Also I think that the Vari-lock was only available in the D30 and D44a axles, not the D35. Then, on top of it all, they require the Quadra-drive axle shafts. I don't know what makes them different maybe someone else can chime in on that...
2000 WJ 4.5L - Stroked, Locked, & Long-Armed Click this -->Think you can beat me? |
#4 | |
I ate what?
As far as the difference in the QD axle shafts and an open axle, the QD shafts are longer so they can get inside the vari-loc and connect. To the OP, if you plan on upgrading to lockers, you need to do more than you think. For the rear, you will have to get an open carrier to put the aussie locker in (currently the only locker available for the D44a). You can't reuse the vari-loc carrier, it's basically a whole unit and if you break it, it's $1250 to replace the whole variloc unit. As for the front, you can replace the unit with a good selectable, like an ARB, OX, ECTED, ect... Hope that helped a little.
Ken 99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers 2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85) 2006 Pontiac G6 GTP - (her's) 2001 Dodge Ram 1500 - CAI, Soft 8's, 31's 2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch 2006 Triumph America 900 - Full Dresser January 2009 Grand Cherokee of the Month (GCOTM)
#5 | |
#6 |
^ good question.
as for how well do they work.... i am running stock tires (29's i think) and both front and rear hooked up very well in muddy areas! i've had the trac lock in my XJ rear and it worked good to.. can't say if it's better or worse come to think about it. i switched to a powertrax locker in the xj and it was definitely a step better than trac loc! havn't put my vari locks through too much yet, but i feel they are comparable to the powertrax. IMHO they may indeed blow with big tires!
Matt |
#7 | |
) and how long it might last. I would think all practicle experience of this is based on old-ish vehicles with clutch packs that already have alot of wear in them. What do you reckon?
2000 WJ 4.7L V8 QUADRADRIVE LIMITED 4" LIFT, BILSTEINS, IRO ADJUSTABLE SHORT ARMS, 285/75X16's BFG MT's & a few other bits & bobs |
#8 | |
I ate what?
#9 |
5.9 Addict
If someone could find the vari-lok version of a D60 (assuming it exists), it would likely be far beefier.
#10 |
I know i'm upping an old thread, but...
To 10achik, my girlfriend has an 04 Overland with the D44 and vari-loks front and rear. Well the rear diff is making noise and binding up when making slow and tight turns and I don't think new fluid is helping any. I'm wondering, if we have to do something about that unit we're NOT spending 1250 for a new vari-lok. Do you think it would be cheaper to buy new axle shafts, open carrier and an aussie? She probably won't wheel the Jeep as we have a Wrangler to take on the trails and she wants to keep this one for a long time. what do you think would be the best in this situation? |
#11 |
Wow this is a great thread. A lot of this I didn't know about the vari loks. Here is my question. Can you use normal diff fluid in these (going for amsoil severe gear oil)? And, do I have to put in a slip lock additive and if so would amsoil's stuff be ok? We've got some similar limited slip stuff at Autozone but on the back of the bottle says do not use in Chrysler quadra drive lsd's. I've never owned anything with limited slips so this is all new to me.
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44 2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT 1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT My build thread http://www.myspace.com/HaleyChicoine http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile |
#12 |
im running 35's with my vari-lock diffs, and they work great so far. Granted, i only have about 6000 miles with these larger tires though. I think they work pretty well. The only drawback is you have to spin the tires to get them to work in low traction situations. IE.. the free tire needs to spin a couple of revolutions before it transfers power to the tire with more traction..
I hope they last long enough that i can upgrade to some real axles though. hahah G-
04 WJ, Limited, 4.7 HO, w/ lots of goodies |
#13 |
5.9 Addict
Greg - I'm impressed that they actually do much that's noticeable with those tires. I'd say run them until they don't work anymore.
#14 | |
BUT the more in there the less it will lock up to much Friction Modifer. to little and it wont unlock
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs 2011 WK2 Laredo with ORA1 |
#15 | |
G-
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
