"Vanishing" Coolant - Page 2 - JeepForum.com
post #16 of 20 Old 02-15-2014, 06:59 PM
Oldfrog
2007 WK
My guesses are ( based upon my own zj..and in no particular order, because I've had them all.):
1. Small radiator leak...blowing back and dispersing. ( very common on ZJs)
2. I had a tiny drip from a heater hose ( bottom side of hose, near the front of engine.) once.
3. Check the radiator cap. In fact , go ahead and replace it if it's the original. Also check the little hose going to the coolant bottle, from the radiator cap area back.
4. Seeping freeze plugs. The ones on the back side of the block are the worst ones to repair. I was lucky and only had to do the 5 of them on the side....( so far). ( might as well replace the exhaust header while it's off...if it's cracked at the collector)
5. Water pump going out....slowly. Twice done on mine.
6. Not happened to me yet ( knock on wood)....heater core seeping.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #17 of 20 Old 02-15-2014, 07:37 PM
Raimundo
Originally Posted by coralman View Post
I see alot of new cars on a cold morning with white smoke out the exhaust. Does it go away? They make a test kit I believe to see if you have combustion gas in the coolant, but I have never bought one. Catalytics produce moisture as a by product which is why there are weep holes in some systems. Smoke under the hood is another matter. I would find the source of that first before going all apocalyptic.
There is a difference between white smoke and water vapor. The water vapor will be present in the exhaust in cold weather as cold air enters a hot engine.
Raimundo is offline
post #18 of 20 Old 02-15-2014, 08:02 PM
Alexandru999
Originally Posted by williams271368 View Post
There is some smoke coming from the radiator area; my rear window is foggy, and won't clear up.
like the other guy said, seems like you have a possible leak from the radiator itself, but doesn't leak, the heat just vapors it ... maybe take it to a shop and have them test the radiator ? i think they do it for like 50$, they even clean it , once u have smoke coming out of there that can be an issue, you said u see no leaks so vapors of your coolant could mean exactly why u see nothing, so is that the problem? smoke from radiator is obviously a problem
as for the rear window fog, you mean tailgate window? beacuse that wont be a problem, there is no air exit near it, usually its windshield, front door windows
Alexandru999 is offline
post #19 of 20 Old 02-16-2014, 08:47 AM
Snowfan2
Heater core leak. Pull up your carpets in front and under rear seat and inspect for moisture.
Snowfan2 is offline
post #20 of 20 Old 02-16-2014, 01:09 PM
Alexandru999
thats what i told him too, but isnt it weird that only the rear window fogs? usually its the front, but yea, like he said, you should inspect anyways
coolant , water pump
