post #1 of Old 03-19-2003, 01:57 PM Thread Starter
windy
valve springs
I have a '95 GC with the 4.0 6cyl that losses power and misses at highway speeds under load. I was told, after checking every other possibility with no improvement, that weak valve springs could be the cause. Does anyone have any experience with that?
Thanks,
Shawn
windy is offline
post #2 of Old 03-19-2003, 10:37 PM
Stocker
Not with a 4.0L, but several years ago my wife's '68 Camaro had similar symptoms with a 327 engine. It had a flat cam, not uncommon in those engines. No idea if that could be your problem, but might be worth considering if you don't find something else. Good luck!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
4.7L H.O Cams and Valve Springs sanitarium16 WK Grand Cherokee & XK Commander Forum 6 07-21-2011 04:46 AM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
Broken Springs ?New Lift Springs @Shocks? '93Jeep ZJ Grand Cherokee Forum 4 02-17-2008 12:30 AM
Up Country springs vs. Quadra Coil Springs JGC03WJ ZJ Grand Cherokee Forum 7 04-01-2007 07:00 PM
You may not post new threads
You may not post replies
