Quantcast Valve Cover Question? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Valve Cover Question?
Old 03-29-2006, 10:07 AM   #1
Jay1982
I am about to replace my valve cover gasket and need to know the torque specifications. 93 GC Laredo 4.0l L6
Jay1982 is offline   Reply With Quote
Old 03-29-2006, 02:20 PM   #2
jeepjeepster
Dude idk what the torque specs are, but that thing sucks to change!
Be sure you get a new pcv elbow(I think thats what its called) b/c you must take the old one off to clear the back of the engine bay. When putting it back on it is VERY hard to keep the gasket lined up. I found it best to put some rtv around the pan to hold the gasket in place.
Ohh, Im sure the torque is very low, its a cork gasket.
jeepjeepster is offline   Reply With Quote
Old 03-29-2006, 02:26 PM   #3
gunthagunth
torque them to 85 inch lbs. (10 Nm)
gunthagunth is offline   Reply With Quote
Old 03-29-2006, 04:32 PM   #4
Jay1982
Jeepjeepster you are correct those things suck to replace, had such a hard time pulling the valve cover off, throttle cables, hoses, etc right over top. Luckily a friend stopped by and helped me guide it back in. And for the torque specs, I called the local Crysler dealer here in St. Pete Florida, talked to a mechanic and he said to just tighten the bolts manually, if the gasket starts pushing out its too tight. Anyway after completing that, i refilled with oil, cranked her up and i hear this ticking sound. Come to find out its one of my pulleys, so now I have to take the belts off and find the pulley that is causing the noise. I am sure the one that is screwed will have play in it. Anyone ever had this problem, if so how much of a pain was it to fix :if you did it yourself: ?
Glock Forum
