Valve Cover Leak - JeepForum.com
post #1 of 23 Old 10-26-2004, 11:30 AM Thread Starter
oct7brian
oct7brian's Avatar
Valve Cover Leak
Ok well I've replaced my vlave cover gasket 2 times in the past 2 year and its leaking again. I've used cork gaskets iis that where I'm going wrong??? Should I use rubber instead???
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #2 of 23 Old 10-26-2004, 11:40 AM
driabyor
driabyor's Avatar
1994 ZJ
you could be overtightening the bolts on the covers....
driabyor is offline
post #3 of 23 Old 10-26-2004, 02:19 PM
Meerkat
Oil cover bolt torque is 75 inch pounds. That's not a heck of a lot.
Properly installed, a cork gasket will seal as well as a rubber gasket.
If I were in your position, I would change to the aluminum valve cover...
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 23 Old 10-26-2004, 03:45 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Because of the valve coverís geometry, it is very important to torque it in the correct sequence. Circular and near round configurations (like square shapes) are easier than elongated shapes like narrow rectangles; which is the shape of the valve cover. I tend to torque things twice. Once at a lower torque rating required, then again at the specified rating. Just a habit from observing old-timers work.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 23 Old 10-26-2004, 03:48 PM
Meerkat
Hey!
Who you callin' old-timer!
That is very good advice though, often overlooked.
Warren
Meerkat is offline
post #6 of 23 Old 10-26-2004, 04:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Warren,
anyone over 30 and able to standup in West BG Virginia is an old timer.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 23 Old 10-26-2004, 04:45 PM
Meerkat
Warren
Meerkat is offline
post #8 of 23 Old 10-26-2004, 05:29 PM
greasefingers
1994 ZJ
Originally Posted by Texas ZJ1
Warren,
Hunter
Ya know driving conditions get better in the winter in WV; because the snow fills in the pot-holes.
Sorry I could not resist.
Cheers Steve
post #9 of 23 Old 10-26-2004, 05:38 PM
Meerkat
Man, you know you've been insulted when you are insulted by somebody from Joisy!
Warren
Meerkat is offline
post #10 of 23 Old 10-26-2004, 07:00 PM
greasefingers
1994 ZJ
Hey thatís Jerzey to you buddy.
Cheers Steve
post #11 of 23 Old 10-26-2004, 11:14 PM Thread Starter
oct7brian
oct7brian's Avatar
Thanks for the info I guess I must have been squeezing the gasket a lil too much it looks like its stretched a little when I looked at it tonight so I guess I'll redew it again this weekend. Well hey guys I'm not a "old tymer" unless being 22 is now one. So whats it like to be OLD????
post #12 of 23 Old 10-27-2004, 06:30 AM
artburg
You can get the rubber gasket with steel inserts at each hole which prevent overtightening if that is the case
artburg is offline
post #13 of 23 Old 09-10-2005, 09:57 AM
K-Pax
K-Pax's Avatar
is this for the I6 engine? i'll be replacing my valve cover today (i hope). but i was actually searching for the valve cover bolt torque specs. this is what i could find.
thanks!
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
K-Pax is offline
post #14 of 23 Old 09-10-2005, 11:01 AM
brandoncrone
You are better off using the rubber gasket, cork is ancient technology and it doesn't work that well. No offense to the older gents! The rubber gasket are used on the newer Jeeps and the almost never leak. The type of rubber actually swells a little sealing the cover even better.
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
post #15 of 23 Old 09-10-2005, 02:05 PM
-Joe-
-Joe-'s Avatar
IF you want to spend $50+ on the rubber gasket. Unless someone knows of a cheaper place..
I used a cork gasket not too long ago and already leaking as well..
I just got a cork/nitrile blend thats supposed to be better then cork at least., it was only $8 from autozone (special order)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
Help with 4.0 valve cover leak Kcolg ZJ Grand Cherokee Forum 8 06-19-2011 04:00 AM
Valve Cover Gasket Possible Leak Wj 4.0 xJoshxx ZJ Grand Cherokee Forum 24 07-14-2009 12:07 AM
2000 wj valve cover leak mselby ZJ Grand Cherokee Forum 4 12-16-2008 01:12 AM
V8 Valve Cover Leak $70 Gasket??? Jon08JK ZJ Grand Cherokee Forum 5 11-07-2007 10:04 PM
Leak at Valve Cover dpierson ZJ Grand Cherokee Forum 1 09-03-2005 12:09 PM
