Valve Cover/ Coil Rail Electrical Connection - JeepForum.com
post #1 of 4 Old 07-16-2009, 12:29 PM Thread Starter
04WJGuy
04WJGuy's Avatar
Another dreaded 4.0L valve cover question.
How in the hell do you get the connector for the coil rail off the back of the valve cover without busting it.
I've tried sliding the clip, pushing everywhere to undo it as per the manual but I can barely even get my hand back there so have no idea if I'm even close to getting it to come apart.
Any ideas before I end up destroying the bloody thing?
Canadian Jeeps Member #35
Black Jeep Society Member #325
The Galloping Green Llamas Member #37
04WJGuy is offline
post #2 of 4 Old 07-16-2009, 12:52 PM
georged
Had the same problem, so I paid a shop $40 to change the plugs I supplied
georged is offline
post #3 of 4 Old 07-16-2009, 01:05 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Unbolt the rail and pop it off of the plugs first. Then you will have more room to play with. Just don't try to pull it out too far as it looked like the PO of my Jeep did and shattered the connector . The jacka$$ then HOT GLUED the connector back to the rail . It was a shotty job at best and I am surprised it wasn't throwing any codes. I'll take some pics of it tonight and post them. I just replaced the rail when I was doing the plugs and noticed this glue job.
~James
ezflip is offline
post #4 of 4 Old 07-20-2009, 05:16 PM Thread Starter
04WJGuy
04WJGuy's Avatar
Had to leave it hooked up to change the plugs but would like to get it disconnected when I change the valve cover gasket. Was even thinking of just relocating it to the firewall if I can ever get it off.
04WJGuy is offline
testing 4 liter 6 cylinder coil rail gpJeep WJ Grand Cherokee Forum 4 11-15-2011 03:43 PM
Coil Rail Assembly Airbird ZJ Grand Cherokee Forum 3 04-23-2009 01:22 PM
Fuel Injector Electrical Connection->Broken Clip pzappa ZJ Grand Cherokee Forum 2 01-05-2009 10:10 PM
2000 gc coil rail question kmo0189 ZJ Grand Cherokee Forum 2 05-03-2008 01:16 PM
Stupid Coil Rail Connector Giseppe ZJ Grand Cherokee Forum 1 01-15-2008 02:47 PM
