Valve cover bolt placement? - JeepForum.com
post #1 of 6 Old 05-23-2012, 06:11 PM Thread Starter
Bmason31
Hey guys, in the middle of putting the beast back together after a head gasket job, and huduh! I forgot to document the bolt placement on the valve covers; some are regular bolts and some are extended for other things to attach to them, and I've no idea which should be where. Anybody got a bead on that? I couldn't find any images or diagrams on the net or in the service manual. It's a 1996 5.2l 4wd.
Bmason31 is offline
post #2 of 6 Old 05-23-2012, 06:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The studs are for the plug wire clips.
The fsm shows where they go, sort of.
I ditched them for stainless, and then t-handle bolts a while ago.
ratmonkey is offline
post #3 of 6 Old 05-23-2012, 07:01 PM Thread Starter
Bmason31
Studs see for the wire clips?
Bmason31 is offline
post #4 of 6 Old 05-24-2012, 05:07 AM
ilive4cars0122
If needed I can take a look at my 5.9 later and let u know.
ilive4cars0122 is offline
post #5 of 6 Old 05-24-2012, 11:59 AM Thread Starter
Bmason31
That'd be great, ilive. I'd really appreciate it. Are they the same valve covers?
Bmason31 is offline
post #6 of 6 Old 05-24-2012, 05:31 PM
ilive4cars0122
Pretty sure there shouldn't be a difference. This is how mine are. The passenger side outside (facing fender) front to back goes stud,bolt,stud,bolt,stud. The passenger side inside (facing the throttle body) front to back goes stud, stud, bolt, stud, stud. The drivers side outside front to back goes bolt, stud, stud, bolt, stud. The drivers side inside front to back goes bolt, stud, bolt, stud, stud.
bolt pattern , bolts , diagram , valve cover
What is on the valve cover... Dluenz ZJ Grand Cherokee Forum 7 03-02-2012 11:28 AM
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
Valve cover paint, need help kedron ZJ Grand Cherokee Forum 4 11-15-2009 07:19 AM
What else should I do with the valve cover off? the88thpianoman ZJ Grand Cherokee Forum 6 02-12-2009 11:58 AM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
