valve body questions, please help in middle of job - JeepForum.com
post #1 of 3 Old 04-14-2011, 09:40 AM Thread Starter
jimmybjames
Hey guys I am in the middle of changing the OD, TCC solenoids and have never done this before. It seems I have to pull the valve body off to change the wring harness. I am also in the middle of the job. How do I go about this? I see the bolts holding it in but when I pull it down what should I expect? Are little check valves going to fall out? Will there be gaskets to worry about? Can I just pull it down and put it right back without much trouble? I just need to get the wiring harness clipped in place.... Please help. thanks
jimmybjames is offline
post #2 of 3 Old 04-14-2011, 09:44 AM Thread Starter
jimmybjames
Oh and its a 97 ZJ 42re AWD 4.0
post #3 of 3 Old 04-14-2011, 10:31 AM
MaintMech
Old and in the way
MaintMech's Avatar
http://www.jeepforum.com/forum/f13/4...torial-911009/
Check it out.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
Where to buy a trans valve body sadass ZJ Grand Cherokee Forum 3 08-25-2009 08:46 PM
Valve body mix up zjsmash ZJ Grand Cherokee Forum 2 07-12-2009 11:05 AM
Valve body help zjsmash ZJ Grand Cherokee Forum 1 07-11-2009 09:08 AM
looking for valve body grand ZJ 5.9 Lohrengel ZJ Grand Cherokee Forum 4 07-01-2008 01:36 PM
In the middle of a 249>242 Swap :Questions" micifus ZJ Grand Cherokee Forum 31 09-25-2007 01:43 PM
