Valve body mix up - JeepForum.com
post #1 of 3 Old 07-12-2009, 09:56 AM Thread Starter
zjsmash
Valve body mix up
I ordered a Replacement valve body for my 98 44RE and the valve body i recieved does not appear to be the same style and possible for a newer year. My 44re has a gold governor pressure sensor and the one i recieved has a black sensor which is also a different style. Is it possible that this valve body could work on my older transmission? Wat would be the differences or problems with using this valve body?
zjsmash is offline
post #2 of 3 Old 07-12-2009, 10:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i wouldn't be concentrating on the sensor color to determine if it's correct.
there is also an updated style of solenoid block for the tcc and od noids.
if the separator plates match then use it.
ratmonkey is offline
post #3 of 3 Old 07-12-2009, 11:05 AM Thread Starter
zjsmash
is the operation of both valve body the same? If they do happen to have the same plates then would the od sensors and everything else be compatible with my transmission
zjsmash is offline
44RE valve body weberdm1980 ZJ Grand Cherokee Forum 13 11-24-2009 09:55 PM
Where to buy a trans valve body sadass ZJ Grand Cherokee Forum 3 08-25-2009 08:46 PM
95 42re Valve body Jeepfordan ZJ Grand Cherokee Forum 1 08-04-2009 01:53 PM
Valve body help zjsmash ZJ Grand Cherokee Forum 1 07-11-2009 09:08 AM
looking for valve body grand ZJ 5.9 Lohrengel ZJ Grand Cherokee Forum 4 07-01-2008 01:36 PM
