Vacuum Leak - Page 2 - JeepForum.com
post #16 of 22 Old 08-15-2009, 09:06 PM Thread Starter
Jones
Consider the following...
Jones's Avatar
Originally Posted by tclaremont View Post
When you find them, pick up a bunch of them. If that cap is shot, you can bet others of the same vintage are not far behind.
Good idea, I'll grab a handful of them. They probably don't cost much.
It almost looks like this one was cut a bunch of times with a knife until it made a hole. Probably not the case though.
Jones is offline
post #17 of 22 Old 08-15-2009, 09:10 PM
daufuskieraised
You didn't take it to Jiffy Lube did you?
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline
post #18 of 22 Old 08-15-2009, 09:12 PM Thread Starter
Jones
Jones's Avatar
No never!
Jones is offline
post #19 of 22 Old 08-16-2009, 01:10 PM Thread Starter
Jones
Jones's Avatar
Problem solved, thanks guys.
Jones is offline
post #20 of 22 Old 08-16-2009, 05:07 PM
newfieZJ
Is that a 360 under all that dirt ? For goodness sake man , get that machine to a pressure washer
Simple fix is a pc of vacum hose , plugged off with a bolt . Properly , these little end tabs can be found at most any auto parts store , as I'm sure , Brian found out by now .
That must have been very hard on fuel Brian , considering it looks like it's been like that for a while ?
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #21 of 22 Old 08-16-2009, 06:10 PM Thread Starter
Jones
Jones's Avatar
That's Moab dirt, it stays forever.
Yep it was a very easy fix, brought the old plug into autozone and bought a little pack of them that were the same size. Took 1 minute to put the new one back on.
We'll see if I notice any change in gas mileage. That and the bad O2 censor couldn't have been helping at all.
Jones is offline
post #22 of 22 Old 08-16-2009, 06:30 PM
newfieZJ
If I ever make to the Moab , I won't wash if off either
My last 1000K trip I got 14 mpg , that was 80% hwy at 80mph and the rest touring in the mountains . Considering my heavy foot , thats not bad . I'm sure I could have drove 60 and got close to 18-20 average for the trip , but wheres the fun in that . My ZJ loves the hwy
1995 Orvis build
1988 MJ build
newfieZJ is offline
WJ Vacuum Leak comptiger5000 ZJ Grand Cherokee Forum 4 12-28-2009 01:43 PM
need some help with a vacuum leak.. (5.2L) vdub ZJ Grand Cherokee Forum 12 12-19-2009 08:39 AM
vacuum leak, where to look? dmolaver15 ZJ Grand Cherokee Forum 4 03-08-2009 07:41 PM
Vacuum Leak 1997 Laredo Dash Vacuum Lines twmattox ZJ Grand Cherokee Forum 4 11-17-2008 08:34 AM
Help, Vacuum Leak DRE97 ZJ Grand Cherokee Forum 0 08-10-2008 03:00 PM
