vacuum leak? - JeepForum.com
post #1 of 12 Old 02-18-2013, 05:03 PM Thread Starter
funkness
vacuum leak?
so i am getting really close to actually driving my jeep after 2 years of waiting and fixing and spending lol soo checking for vacuum leaks can't find any but yes there's always a but at this spot there is no suction from the hose going to the front of the jeep does this mean there's a leak?
funkness is offline
post #2 of 12 Old 02-18-2013, 08:16 PM
ZeeJay1997
It probably means someone has bypassed the evap canister
Is there another line coming off the purge solenoid that is blocked off?
ZeeJay1997 is offline
post #3 of 12 Old 02-18-2013, 08:32 PM
ZeeJay1997
After further review, plug that line up to the boot on the purge solenoid.
post #4 of 12 Old 02-18-2013, 08:39 PM Thread Starter
funkness
I took it off is there posta be suction at that hose?
funkness is offline
post #5 of 12 Old 02-18-2013, 08:55 PM
ZeeJay1997
When the purge solenoid cycles, there should be vacuum there, When it's running, the purge solenoid should click after you've been cruising for a while.
post #6 of 12 Old 02-19-2013, 04:08 AM Thread Starter
funkness
So there is suction from the side that has the purge solenoid but not from the other side?
funkness is offline
post #7 of 12 Old 02-19-2013, 04:19 AM
ZeeJay1997
vacuum is created by the intake manifold. the purge solenoid meters it to pull fuel vapors out of the tank towards the engine through the canister.
post #8 of 12 Old 02-19-2013, 07:37 AM Thread Starter
funkness
I think we are going back and forth on what i am asking lol heres a photo to try to point out what i am asking mind you i tested the vaccum at the crusie control where it has plenty of vaccum then it runs down under the battery box.
funkness is offline
post #9 of 12 Old 02-19-2013, 03:54 PM
ZeeJay1997
I'll keep it simple. The solenoid sucks on that hose you have in your hand. No vaccum lines run arcoss front of vehicle.
post #10 of 12 Old 02-19-2013, 03:59 PM Thread Starter
funkness
Where does the vacuum hose that goes under the battery box go?
funkness is offline
post #11 of 12 Old 02-19-2013, 04:03 PM
ZeeJay1997
Under the battery box.
Thats the line to the vacuum reservoir... just a box full of vacuum.
post #12 of 12 Old 02-19-2013, 07:53 PM Thread Starter
funkness
Well i made a diy smoke vacuum tester today and found out that my throttle body gasket is leaking very bad but would that cause a 6-7 inch of pressure drop in my vacuum pressure? Getting new gasket tomorrow
funkness is offline
