Quantcast V8 5Speed Swap conclusion, sort of. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > V8 5Speed Swap conclusion, sort of.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 10-09-2006, 02:36 PM   #1
S C
So this past week I attempted the 5 Speed swap on my 5.2L ZJ. Long story short everything didn't fit like I intended, so for now I put all my old stuff back in.
Here's some notes for anyone else who attempts this swap.
I used an NV3500 out of a 2000 Dodge Dakota V6 with a 231D.
The starter pocket is on the wrong side, of the bellhousing, I thought it might be able to squeeze in, but the exhaust manifold is to close, and the upper suspenion arm will contact the starter at ride height.
I made another stupid mistake, and didn't take into account the tone ring on the V6 has a different number of notches then the V8, so I got a V8 flywheel and clutch.
This is another major issue, the crank on the 5.2 does not come machined for a pilot bearing. Its a few thousandths off, I drilled out the extra material with a 1" bit, the pilot bearing is exactly 1" in diameter. The bearing pressed in, but was not as tight as it should have been, so when I try this again, we'll make a couple tig tacks to hold it secure.
The crossmember needs to be moved forward since the V6 trans is not as long, not really a big deal.
The pedals will need modification unless you happen to find a V6 Grand which is hard to find. The YJ pedals I have are going to take a bit of modification to fit.
I think those were all the major issues, just about everything that could fight me on this project did. I'm tired, that auto trans is HEAVY.
Also, the CPS from the auto is to long, you'll need a V8 Manual CPS, for some reason they decided to make the tone rings a .25" different....
GM's are so much easier for this sort of thing, everything interchanges so much easier.
S C is offline   Reply With Quote
Old 10-09-2006, 03:41 PM   #2
MSU.WJ
Why did you go with the NV3500 and not an AX15 or AX4 or something equivalent that was actually used in other jeeps?
2000 WJ Laredo 4.7 NP242
3" Lift, 31" MT/Rs, Aussie Locked D44A, JKS sliders, more
Want places to wheel? Support the Blue Ribbon Coalition: http://www.sharetrails.org
MSU.WJ is offline   Reply With Quote
Old 10-09-2006, 03:53 PM   #3
anticrombie
Ax15 won't mate to the 5.2.
anticrombie is offline   Reply With Quote
Old 10-09-2006, 04:53 PM   #4
S C
the AX 15 isn't as strong as the NV3500 as well.
Old 10-09-2006, 05:47 PM   #5
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Woody suggested that it should work with a Dakota 3.9L bellhousing.
If you get a fly wheel with 8 evenly spaced notches you can use the stock CPS sensor if you make a small spacer. I ran into this too after I put on my flywheel.
EDIT: I goofed! The Jeeps use the NV3550! Thankyou!
Also, my pilot bushing pressed right in just fine... I wonder if there was a change made in the end of the crank fron '94-'97 It was the pilot bushing that came with my Luk clutch kit.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 10-09-2006, 06:01 PM   #6
S C
we tried the pilot bushing in the 5.2 in my jeep and the 5.9 that were in the shop, the 5.9 had an even smaller hole.
Old 10-09-2006, 06:11 PM   #7
S C
Tim, I just looked at your build thread, is that a brass pilot bushing in your crank? I recieved a roller bearing pilot bushing.
Old 10-09-2006, 06:18 PM   #8
Woody
Retired back to Bowties
Woody's Avatar
1985
Tim, Jeeps didn't use the 3500, they used the 3550.
Also, I thought I told everyone that YJ pedals won't work. XJ pedals work in the ZJ bracket, and that's about it.
I didn't think about the starter location. Hmmm....which side of the 5.2L is the starter on in a Ram? That bellhousing should work as well.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Old 10-09-2006, 06:32 PM   #9
S C
The YJ pedals will work, I'm not to worried about it, though if i stumble upon a set of XJs I'll pick'em up, the local boneyards by mean didn't have any though.
I'm not sure which side the starter is on a ram, I won't be able to use that bellhousing though, because the 3500 uses an integral bellhousing, so I'd need to get a whole new trans which would be another money sucker. I figure you can just cut the starter pocket out and rotate it around to the other side, that should do the trick.
Old 10-09-2006, 06:50 PM   #10
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Thanks for the correction Woody!
The 88-91 Ram bellhousing I have (for the 435) has a driverside starter.
KD8EBC
'94 ZJ 5.2 LTD
Old 10-11-2006, 04:44 AM   #11
S C
Tim, was that a brass pilot bushing?
Old 10-11-2006, 07:12 AM   #12
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Yeah it was
You can barely see it in this picture:
KD8EBC
'94 ZJ 5.2 LTD
Old 10-11-2006, 07:32 AM   #13
S C
I'm wondering if thats why the bearing didn't fit, because the bearing I got was a roller. Maybe the brass one was a slightly different size.
Old 10-11-2006, 10:20 AM   #14
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
That is a definate possibility... what is the OD of your input shaft? I'm surprised there was enough clearance for a roller-type pilot bearing...
KD8EBC
'94 ZJ 5.2 LTD
Old 10-11-2006, 10:24 AM   #15
S C
i don't know the size of the insput shaft off the top of my head, it fit fine into the bearing. The roller bearing was a few thousandths off, so I drilled it out till it fit.
Glock Forum
