Using jackstands with curved saddles on the frame rails - Page 2 - JeepForum.com
post #16 of 23 Old 06-08-2013, 04:09 PM
Candymancan
You guys and the wood lol.
Listen they use Woodblocks to hold boats up on dry dock... and they use wood blocks to hold 80 ton tanks up in the air.. Wet wood doesnt compress.. Maybe if you were using a dry rotted peice of 2x4..
Go to about 7:10 on this video to see the use wood to hold the tank up..
Candymancan is offline
post #17 of 23 Old 06-08-2013, 07:17 PM
5-90
5-90's Avatar
1988 XJ Cherokee
http://www.youtube.com/watch?v=Hu6pP9JH3as
And they're careful about the shape of the wood and orientation of the grain, believe me! What driveway wrench can say the same thing? For the most part, we're hobbyist mechanics, not engineers.
Wood is an excellent engineering material - strong, light, and easy to form. However, it's also PAINFULLY easy to screw up with!
I'm familiar with the myriad uses of wood in engineering - from Balsa to lignum vitae. I'm also familiar with how it's designed and engineered when used - you don't think they just just any old wood block to hold up tanks or ships in drydock, do you? Or that they just run down to the Home Depot when they need more? Trust me - most of the stuff you find in the hardware store is rejects from high-strength engineering uses, or stuff that they know would be rejected, so they didn't bother to submit it!
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #18 of 23 Old 06-08-2013, 08:30 PM
phitmein
phitmein's Avatar
While I agree that the wood could be dangerous on the stands, as long as we are talking wood and heavy stuff how about trains and railroad ties .
phitmein is offline
post #19 of 23 Old 06-08-2013, 08:41 PM
Virmagicus
Virmagicus's Avatar
What they are using is referred to as "blocking & cribbing" along with a hydraulic ram. I was trained to use this method and is no way the same as sticking a piece of wood in between the saddle and load. You should never alter a jack stand in anyway. If you make the saddle wider it can cause the jack to tip over...even if you weld a plate underneath it.
Jeff
Virmagicus is offline
post #20 of 23 Old 06-09-2013, 01:31 AM
ShinyWJ
Just put the Jeep on the jack stands. Even if it's resting solely on the "tips"... you'll be fine. So you might get a couple little "dents" in the frame rail, but it's fine. Use some good judgement. I, like another poster, shake the vehicle once on the jack stands to check for stability before crawling under. I also put the tires under the vehicle just in case.
Also make sure your jack stand base doesn't sink into whatever it's placed ON...
ShinyWJ is offline
post #21 of 23 Old 06-09-2013, 03:35 AM
shaban
Ok thanks for the advice guys. Didnt realize it was unsafe.
shaban is offline
post #22 of 23 Old 06-09-2013, 06:32 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I had to laugh about the comment, "put it up on the stands and shove it, if it doesn't fall off, it's safe." So, if it falls and gouges the crap out of the doors, it wasn't safe and really dorked up.
Be careful, do it the correct way.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #23 of 23 Old 06-09-2013, 10:50 AM
JohnCrabtree
1994 ZJ
Hunter
Better to dent your jeep than kill yourself.
JohnCrabtree is offline
