using F150 coils for lift on ZJ? - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > using F150 coils for lift on ZJ?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 03-16-2012, 07:56 PM   #76
jtackerman28
So what year coils? I'm going tommarow
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline   Reply With Quote
Unread 03-16-2012, 08:00 PM   #77
1stblack97ZJ
Originally Posted by adrock85 View Post
Cause they only made like 10 different body style thunderbirds...
It's not about the bodystyle, it's about the coils 1983 through 1997 ford thunderbird coils will work.
[URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/September%20Nineteenth%202011/IMG_1210.jpg?t="]Blacked out 97 ZJ 4.0, 4" IRO + Junkyard lift kit[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/Flex/IMG_1075.jpg?t="]32" Maxxis ATs, 15x8 d-windows[/URL], [URL="[IMG]http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirtyth%202011/IMG_0567.jpg[/IMG]"]cherrybomb turbo[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirteenth%202011/IMG_0545.jpg"]gas tank skid[/URL] and [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirteenth%202011/IMG_0539.jpg"]t-case skid[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/December%20Twenty-fifth%202010/IMG_0183.jpg"]spectre cone air filter[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/May%20First%202011/IMG_0575.jpg"]Baja off road lights[/URL]
[CENTER][URL="http://www.jeepforum.com/forum/f197/1stblack97zjs-build-thread-frankinjeep-1121844/"][COLOR="Blue"][SIZE="4"]MY BUILD THREAD[/SIZE][/COLOR][/URL][/center]
1stblack97ZJ is offline   Reply With Quote
Unread 03-16-2012, 08:03 PM   #78
jtackerman28
Thank you
Unread 03-16-2012, 08:12 PM   #79
1stblack97ZJ
Originally Posted by jtackerman28 View Post
Thank you
Just an FYI in case you didn't already know, you have to use the isolator from the thunderbird coil over and drill a hole through it and put it over your stock isolator.
You can kinda see it here: http://www.jeepforum.com/forum/f22/b.../#post12443428
Unread 03-16-2012, 08:29 PM   #80
jtackerman28
Do you mean put it over the bump stop post? And will the f to r and t bird coil put me about 3 in up?
Unread 03-16-2012, 08:34 PM   #81
1stblack97ZJ
Yep. It will all make more sense when you have the parts in front of you lol. I put v8 front zj springs in the back and v8 tbird springs in the front, I'm sitting at 4". Make sure you get v8 or base model v6 tbird springs, the se model tbird v6 springs are too stiff.
Unread 03-16-2012, 08:36 PM   #82
jtackerman28
I have a i6 so where will I be? Any death wobble on stock arms?
Unread 03-16-2012, 08:37 PM   #83
j.love
1994 ZJ
Originally Posted by vegasZJ View Post
Claytons long arm 7" coils 2" spacers 35" km2s. No trimming no rubbing.
now all you need is to scrape up and buy that fourth tire. it will ride a lot better that way.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline   Reply With Quote
Unread 03-16-2012, 08:53 PM   #84
vegasZJ
Lmao but the steel jack wheels ware so much better. But just to clarify that is not my rig it is my friends i helped him build. Mine is the white 98 in my profile on 33s. By the end of the year it will be on 37s (hopefully). We use our rigs to crawl and actually hate everything about the mud. Just not our style. Polkas rig is really really nice and he wheels the hell out of it. And ive seen more than one picture of mud up to his mirrors.
When in doubt throttle out!
vegasZJ is offline   Reply With Quote
Unread 03-16-2012, 09:04 PM   #85
1stblack97ZJ
I have an i6 too so I pulled the v8 zj coils from the junkyard. If you use the i6 front coils in the back, you'll probably be about 3" in the back and 4" in the front. You will most likely have death wobble on stock arms. I lucked out and found a set of extended front lower control arms in the junkyard, replaced the bushings, popped em in the jeep and the death wobble was gone.
Unread 03-16-2012, 09:07 PM   #86
jtackerman28
I might be able to pick some arms up off of a lifted xj. I think it is like a 2in lift. Any springs that will give me 3 in?
Unread 03-16-2012, 09:09 PM   #87
1stblack97ZJ
Not that I know of. 90s tbird coils give a little less lift than 80s so that would be your best bet.
Unread 03-16-2012, 09:11 PM   #88
jtackerman28
OK ill try for that then cuz I don't really wanna go 4in. Did you do a new front track bar?
Unread 03-16-2012, 09:12 PM   #89
1stblack97ZJ
Yep I got the IRO double sheer.
Unread 03-17-2012, 04:59 AM   #90
adrock85
That was the body style I was assuming you meant, But I will say that each body style/generation thunderbird has a different suspension. So it is kinda about the body style. Just sayin..
adrock85 is offline   Reply With Quote
