Using car audio block as accessories distribution block? - JeepForum.com
post #1 of 4 Old 07-12-2011, 01:53 PM Thread Starter
speedbucket
as the title says.
i dont see any downsides and i have several of these(pic) laying around that will accept 1/0 power cable, and then of course you can use the proper fuse for the particular accesorie light,CB,air compressor.etc......
any thoughts? Sqauzz's mess under the hood inspired me
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #2 of 4 Old 07-12-2011, 06:56 PM
MaintMech
Old and in the way
MaintMech's Avatar
I don't see why not. Current is Amps and if they're rated at the amperage you fuse them for nothing should go bad. Just make sure that they are compatible with copper wire.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 4 Old 07-13-2011, 07:27 AM Thread Starter
speedbucket
thanks for the response, i thought it was a pretty good and cheap idea as they only cost $7-$9 for really nice ones with waterproof housings.
post #4 of 4 Old 07-13-2011, 08:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
going to be difficult getting agu fuses in the proper sizes for the downstream equipment. other than that, not a problem.
ratmonkey is offline
New guy on the block LILGRIZZ ZJ Grand Cherokee Forum 5 04-22-2011 07:02 AM
Rear brake lines and distribution block Johnreed28 ZJ Grand Cherokee Forum 8 03-09-2011 08:34 AM
Axle Vent/Brake Distribution Block Bolt Snapped 98GCLimited ZJ Grand Cherokee Forum 3 08-15-2009 05:18 PM
WK CRD block into WJ ??? Doody WK Grand Cherokee & XK Commander Forum 21 05-02-2008 10:07 PM
is there a vin on the 4.0 block? ta2oodfreak ZJ Grand Cherokee Forum 2 08-24-2007 11:58 AM
