using a/c makes my jeep run hotter? - JeepForum.com
post #1 of 26 Old 06-28-2013, 04:39 PM Thread Starter
BigJohn96ZJ
So i recharged my a/c last week and been using it since its 95+ outside. But it makes the jeep run at a little over 210 which is too hot for my liking. It stays at 180-190 without the a/c on. I just replaced the water pump and thermostat (180) aswell. What can i do to keep it cooler?
96 ZJ Laredo 4x4, 5.2l, 2.25" budget boost, 31 bfg m/t KM2
BigJohn96ZJ is offline
post #2 of 26 Old 06-28-2013, 04:51 PM
WhiteOut
WhiteOut's Avatar
New rad, flush the system and make sure there is no air in the system.
WhiteOut is offline
post #3 of 26 Old 06-28-2013, 05:34 PM
a70eliminator
The a/c condenser when active is running has a design temperature of 30 degrees over ambient. Example- 70 degrees outside temp the condenser temp is about 100 degrees, if it's 95 outside then the condenser is running about 125 degrees. The condenser it situated right in front of the radiator so doesn't help that's for sure but where else you going to put it, it needs airflow that's real important.
With a 15psi cap you should be good to well over 210 my 5.9 lately with ac on is hitting 210 on a hot day.
a70eliminator is offline
post #4 of 26 Old 06-28-2013, 05:47 PM
um7267
mine is always right at the middle marking, so thats where i like it to sit and assume it is normal
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #5 of 26 Old 06-28-2013, 05:49 PM
Candymancan
its a known fact running the a/c makes the engine warmer...
Candymancan is offline
post #6 of 26 Old 06-28-2013, 06:28 PM Thread Starter
BigJohn96ZJ
Thanks for all the input guys. It had a new rad 2 years ago. Im just dont like my motor running that hot. It hard starts and is a total dog when it gets that way. So i guess im having to choose Between cold a/c and jeep running normal.
post #7 of 26 Old 06-28-2013, 06:33 PM
a70eliminator
The a/c drains about 4hp from your engine, so yea it can make a noticable difference on how much you have to push on the skinny pedal, I can feel right away if my a/c is on, the extra drag may be what your feeling and it's not temperature related.
But again if your in need of tune up, running the a/c will certainly drive it over the top.
post #8 of 26 Old 06-28-2013, 07:00 PM
JBrady5555
Mine drops from 14 volts to 12-13 when I turn on the a/c. is that normal?
JBrady5555 is offline
post #9 of 26 Old 06-28-2013, 07:26 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
You are getting rid of the heat of compression, the heat inside the cab, before you even begin talking about ambient temperaure so yeah it may run a bit hotter. Some things you could check are to remove the upper radiator support and check for crap trapped between the radiator and condensor. It often has bugs, leaves and general crud there. My 4.0, sits at probaly { with guesstimate gauges} 195 with A/C off and 210 with it on. Check the condition of the end baffles on the radiator to make sure you aren't bypassing air. As Whiteout said make sure the cooling system is clean. Is the A/C charge correct? Is it cooling to your liking? The temps you are desribing aren't that out there.
Originally Posted by HighLonesome
coralman is offline
post #10 of 26 Old 06-28-2013, 07:32 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Flush the system, change the coolant, don't use the aircon so much.
The aircon results in an increased electrical loading (fan, compressor clutch, cooling fan,) which increases engine loading.
Driving the compressor proper results in increased engine loading.
And, the aircon condenser is usually in front of the radiator core - which increases THERMAL loading by reducing heat rejection capacity of the system.
There are a few things you can do to pull your operating temperature down while running aircon (dumping in a bottle of Water Wetter certainly won't go amiss, either!) but your operating temperature will almost invariably rise a bit with the aircon on - simple physics.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #11 of 26 Old 06-28-2013, 08:50 PM Thread Starter
BigJohn96ZJ
Well it did it again tonight at work. turns out the whole getting way too hot thing is cuz my friend that was there with me changing my water pump filled it up with only water!! Hence NO ANTIFREEZE!! It was sitting on his carport floor unopened where i left it a week and half ago. It wasnt just hot it was boiling in the reservoir.
Needless to say ill be doing a coolant flush in the morning and adding water wetter too. Thanks alot guys.
Ill be posting back if it doesnt fix it.
post #12 of 26 Old 06-28-2013, 08:55 PM
Candymancan
Actually.. Plain water cools better then antifreeze does... Antifreeze is just that... ANTI FREEZE.. its also to keep the metals in the system from corroding and from the system boiling plain water boils at like I think 212-220f ? Or something like that and with antifreeze it brings it up to around 260.... Other then that when you are in a very hot area like say Arizona its better to have a 70% water 30% antifreeze solution because water cools faster then antifreeze does..
Drain it for one because he probly used a garden hose to fill it up and you probably have all kinds of minerals now in the system which can cause calcium build ups.. You need to use distilled water.. They sell gallon jugs in the store for like 90 cents.. buy a bottle of pure antifreeze and mix it 50/50 yourself.. Buy one of those $10 gauges from the auto parts store.. they measure the mixture and tell you how cold it will get till it freezes and how hot till it boils.
post #13 of 26 Old 06-28-2013, 09:17 PM
a70eliminator
Antifreeze/COOLANT raises boiling point, without it some boiling within the internals of the engine in the hottest places like combustion chambers and cylinder walls is eminent, water boils at roughly 240 @10psig pressure cap, the combustion chambers can run 5-600 degrees so water will flash off to steam under direct contact, water is the best heat transfer fluid under the right conditions but inside your engine isn't one of them, Antifreeze/coolant is a must have.
post #14 of 26 Old 06-29-2013, 11:08 PM Thread Starter
BigJohn96ZJ
This morning i went to oreillys with a friend and bought some coolant and water wetter.when i got home i ran the jeep up to temp took the hose and put it in the rad and pulled the drain plug on the bottom to flush out all the old water. Then after it was clear i plugged it back up and filled it up. Ran great and was at a normal temp all day but i forgot to turn on the a/c. Oops
post #15 of 26 Old 06-30-2013, 01:52 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Er - "flash temp" in the combustion chamber is closer to 1600-1800*F, just so you know...
5-90 is offline
