using 93-95 fog light brackets on a 98? - JeepForum.com
post #1 of 10 Old 12-25-2011, 06:33 PM Thread Starter
nicklopic
I got some Hella 500ffs Christmas and I've been planning on mounting them on my bumper for quite some time. I can't though, for the life of me, find whether or not i can use the fog light brackets from the old style zjs on my 98.
it seems there are holes pre-drilled on the crossmember that seem like they'd line up for the brackets. I know the top part of the brackets probably wont work.
If someone could let me know, i'd really appreciate it. (worse comes to worse I'll fab some bracket up)
P.S Merry Christmas and happy holidays to everyone
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #2 of 10 Old 12-25-2011, 06:55 PM
Myusername1674
im sure it will work fine, i attached mine by just going to ace hardware and buying some brackets with some bolts to fit, only cost like 8 bucks.
I had originally put new fogs on the old factory brackets but i wanted to move them, so thats why i bought new brackets.
Myusername1674 is offline
post #3 of 10 Old 12-25-2011, 08:44 PM Thread Starter
nicklopic
i feel like im gonna end up needing to do something like what you did
anyone else have an answer please?
98' ZJ 4.0
post #4 of 10 Old 12-26-2011, 07:25 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Won't work without cutting up the header panel and grille
ratmonkey is offline
post #5 of 10 Old 12-26-2011, 08:40 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The stock brackets suck, go ahead and fab something up.
HighLonesome is offline
post #6 of 10 Old 12-26-2011, 01:27 PM
KoreaZJ
1994 ZJ
When my stock fogs finally fell apart, I modded the stock brackets for Hella 550's. Flipped the brackets upside down, cut the outer ends off, drilled holes to mount the lamps, slight bend, notched the bumper cover slots slightly wider and longer.
KoreaZJ is offline
post #7 of 10 Old 12-28-2011, 11:55 AM
ExpeditionXJ
Hmm, i was planning exactly this as well. 93 brackets on my 98 with the Hella's in garage.
Rat, i'm assuming the issue is the lowered grill on the 96+ that makes this not work? I hadnt realized that till now.. couldnt the brackets just be lowered a tad to clear the grill assembly?
ExpeditionXJ is offline
post #8 of 10 Old 12-28-2011, 12:37 PM
PolkaPower
Just go down to Lowes and get some big L brackets and bolt them on the the under bumper then make some cuts on the plastic bumper so they fit.
PolkaPower is online now
post #9 of 10 Old 12-28-2011, 04:26 PM Thread Starter
nicklopic
i just made brackets today.
I bought some flat steel from ace and some self tapping bolts, cost me $9. Brackets seem pretty solid and the holes already in the bumper worked fine with 1/4 bolts (might get some thicker bolt though)
They're not great, but considering the tools I had to use, they turned out awesome. I think I might do like a write-up for it once I'm 100% done because I couldn't find anything like that at all.
98' ZJ 4.0
post #10 of 10 Old 12-28-2011, 04:28 PM Thread Starter
nicklopic
Here's what they look like
98' ZJ 4.0
brackets , driving lights , fog light , usage , zj
Windshield Light Brackets Cutlass ZJ Grand Cherokee Forum 4 11-19-2011 08:54 PM
93-95 ZJ Fog light brackets on a 96-98 JCZJ ZJ Grand Cherokee Forum 3 02-13-2008 07:30 PM
stock 93-95 fog light brackets on 96-98? notfast ZJ Grand Cherokee Forum 1 10-22-2005 09:18 PM
stock fog light brackets petef1 ZJ Grand Cherokee Forum 0 04-04-2004 06:28 AM
