Using 10w-40 due to low oil pressure? - JeepForum.com
post #1 of 19 Old 12-17-2012, 09:46 AM Thread Starter
streetzj
I'm using 10w-40 to increase my low oil pressure, which is caused by bad bearings. It increased the pressure from 5 psi to 9 psi over 5w-30 when I changed the oil this summer. But now it's winter here in Minnesota -- which weight should I use?
It seems to me that it's a matter of the least worst -- when the engine is warmed up after about 20 minutes, the 5w-30 will cause the pressure to go back down to 5 psi, which is bad. But when I start it in the cold, the 10w-40 is too thick to reach the top right away, which is bad.
Either way, the oil won't reach the top at some point. And important note -- the pressure is only low at idle and is fine at cruising speed, and increases to normal from low pressure when I accelerate.
streetzj is offline
post #2 of 19 Old 12-17-2012, 09:51 AM
JohnnyZJ
gear oil will bring it up a bit.
keep the jeep plugged in that will help
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 19 Old 12-17-2012, 10:00 AM
Candymancan
Why are you even using 5-30 anyway they are ment to use 10-30.. ill never understand why ppl do that..
Candymancan is offline
post #4 of 19 Old 12-17-2012, 10:03 AM Thread Starter
streetzj
I guess I've always been told to use 5w-30?
But I've also been warned against using 10w-40 in Minnesota winters...
streetzj is offline
post #5 of 19 Old 12-17-2012, 10:18 AM
PolkaPower
Why don't you use 5W-40?
PolkaPower is online now
post #6 of 19 Old 12-17-2012, 10:19 AM
PolkaPower
It's the same weight warmed up. Just gets up into the motor faster at start up. It seems to have rid me of my cold morning knock I was having.
post #7 of 19 Old 12-17-2012, 10:20 AM
Uniblurb
Uniblurb's Avatar
I wouldn't even use 10W40 in he summer and follow the spec to use 10W30 year round in all our Jeeps. Always have and always will. And yeah, my oil pressure is just a little low at idle on my 96 4.0 but don't believe it's doing any damage and picks right up when accelerating.
For MN winters believe I'd be using a block/engine heater plugged in overnight if possible.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #8 of 19 Old 12-17-2012, 10:54 AM
JohnnyZJ
anything thicker in the really cold weather and the jeep will likely not start. you woulnd't see anything like that in Virginia. (unless you guys get -40 degrees there?)
i run 5w30 in the winters. much smoother in most situations. 10/30 in the summer.
keep in mind, the heavier oil will help with pressure but on cold mornings its as thick as molasses. i'd keep it plugged in if you do that for sure
JohnnyZJ is offline
post #9 of 19 Old 12-17-2012, 11:08 AM Thread Starter
streetzj
Ok, I think I will go with a 5w for the winters, because it does get well below zero here in Minneapolis. Outstate and northern Minnesota see -40 like your part of Virginia.
I kinda like the earlier idea of 5w-40, but some of you guys seem against a 40w, even with my bad bearings?
And what again does anyone think is the cause of that knocking sound?
streetzj is offline
post #10 of 19 Old 12-17-2012, 05:19 PM
zander21510
I started using 5w40 Rotella T6 synthetic just to see if it was any good. It got rid of some noises, seems like good stuff. Oil pressure is pretty stable except at warm-up where it can get somewhat low idling after a stop.
zander21510 is offline
post #11 of 19 Old 12-17-2012, 05:34 PM Thread Starter
streetzj
I'm also thinking of trying that actually. Thanks!
streetzj is offline
post #12 of 19 Old 12-18-2012, 04:36 AM
Foundrydude
Be gentle to it when it starts. A bit of knocking on cold start is tolerable. A bit of knocking on a warmed up engine is certain death.
Basically run whatever oil you need to keep it from knocking when warm, and live with whatever it does cold. I wouldn't hesitate to use 20-50 if that's what it took to prevent knock while driving
Foundrydude is offline
post #13 of 19 Old 12-18-2012, 04:47 AM Thread Starter
streetzj
Thanks.
I now think the knocking is a lifter, so that's my next thread!
streetzj is offline
post #14 of 19 Old 12-18-2012, 04:59 AM
LouC
2007 WK
I've been using 10w/30 Valvoline Maxlife and the oil pressure on my 98 ZJ 4.0 is 30 psi hot at idle, 40-50 driving..
LouC is offline
post #15 of 19 Old 12-18-2012, 03:37 PM
Foundrydude
Thanks.
That's called ticking
