Quantcast USA Alloy Axle Tube Seal issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > USA Alloy Axle Tube Seal issues
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-12-2009, 02:07 PM   #1
Scottso699
Scottso699's Avatar
Has anyone come across this problem when installing Axle Tube Seals on their Grand Cherokee? I took a look at the directions and all for the axle tube seals I got that are from USA Alloy - and then I took a look at the end of the inner axle shaft on my Dana 30 - There seems to be a stub or crown on the end of the axle shaft that extends for about 2 inches. - this makes it impossible to install the axle tube seal as the end by the "ears" part for the U-Joint has a thick base/crown/stub where it connects to the shaft. Is this just a Grand Cherokee thing? I will most certainly have to return these seals as there is no room there to install them with this stub on the end of the axle shaft (and I am not referring to the plastic cap thingy either)
Scott
1998 ZJ 5.9L Limited
Pictures
2006 WK Overland
Scottso699 is offline   Reply With Quote
Old 11-12-2009, 07:24 PM   #2
Travis873o
can you take pictures? that would help out a lot
Built not Bought #170
My build thread:
http://www.jeepforum.com/forum/f197/travis873o-build-thread-1295705/
FOR SALE: ZJ 231 bezel,
PM me if you need one.
Travis873o is offline   Reply With Quote
Glock Forum
