Upper and Lower Ball Joints - JeepForum.com
post #1 of 18 Old 12-10-2007, 09:30 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
I took my truck to get looked at for squeeking and clunking in the front end while turning at low speeds. It was most noticeable when the weight shifts, like while turning at 15mph, or into a parking spot or something. They told me that the sway bar bushings were bad and needed replacing.
I had them replace it, but they told me after fixing it, the squeeking went away, but the clunking was still there and after further inspection, it seems that my upper and lower ball joints are bad and need replacing on both sides.
They told me it would be an $850 repair that would take about 6-8 hours to complete. I made the appointment 2 weeks ago for tomorrow, but after looking at the long scheme of things, with christmas coming up and everything, its really going to make my budget tight....
my question is, yeah it makes noise while turning and sounds bad, but how bad is it? Is this something that is a dire need to be fixed? Or will nothing happen if I just wait a while to get it fixed. How long is too long?
Thanks
Mike
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #2 of 18 Old 12-10-2007, 09:52 PM
nierace
nierace's Avatar
2003 WJ
The only issue you will run into is abnormal/excessive wear on the tires if they are bad.
Definately not a safety issue and it won't cause for problems with other components.
It is a PITA job - the parts are approximately 200 bucks for each side. It's a time consuming job, but anyone could do it with a ball joint press which can be had at a local autoparts store. Still it is a bear of a job so it may be worth the $400 to have them do it if you don't have the spare time or interest to do it yourself.
Also do you have a lift or want a lift in the future ? If you do now would be a ideal time to get adjustable ones which would help keep your caster in check if you did lift the rig.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 18 Old 12-10-2007, 09:55 PM
Yardman Harry
O
Yardman Harry's Avatar
Well, given that your ball joints hold your knuckle on the axle, and your knuckle holds the wheel bearing, and the bearing holds the tire, i would suspect that a broken ball joint whilst driving at highway speeds could lead to a serious accident. However...
How long have you been driving it like this? Do yourself a favor, jack up one tire at a time, and stick a crow bar under the tire, and pry against the ground and the tire as if you are trying to lift the jeep up off of the ground, if you have massive, massive play, you are in serious trouble. If... you can only tell that the tire is moving while your hand is on the tire, then you should be alright. BUT!! i wouldnt recommend skipping the appointment.
Also, I did my ball joints for around 200 bucks. and two nights... Just something to think about.
Good luck!
Harry
PS: also check to see if your sway bar links are broken, perhaps they are what is causing the clunk
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #4 of 18 Old 12-10-2007, 09:56 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
Would adjustable ones cost more? I had planned on lifting it at one point, but with me getting ready to graduate college and student loans plus living expenses soon piling on, I don't think I see that in the near future, as much as I'd like to. But i'm glad to hear I can cancel the appointment if I wanted and it wont cause any further damage or be a safety issue. The tires I have on there now are Bridgetone Dueler Revo A/Ts with about 8k miles on them
Thanks!
post #5 of 18 Old 12-10-2007, 10:02 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
Good luck!
Harry
Wow conflicting views, now I'm on the edge again, haha. I don't really have time to jack the car up and look seeing as I've work tomorrow morning. The mechanic didn't sound like it was a dire emergency, just that it needed to get done. However, I don't want any safey issues arising....
It doesn't sound too bad to me, it only notice it clunks maybe half the time that the weight shifts, but it definitly is noticable. The sway bar links arent broken, I just had that serviced, and I've looked at it since then and they are fine. They actually replaced the bushings with greeseable ones which is really nice.
I could maybe cancel the appointment perform the test you told me and then see from there to maybe re-schedule. I had it jacked up not too long ago and I didn't remember too much abnormal play in there because I usually check stuff like that while I have it in the air.
The guy told me about the ball joints maybe 2-3 weeks ago while I was still at school. I never really noticed the clunks as much as I did the squeeks, and now that the sway bar bushings had been replaced and there isnt any more squeeking, I notice the clunking a lot more. But if I had to maybe put a start date on when I first noticed it i'd say maybe 6 months? But its no where near as much as i've been hearing it lately. Before I'd only hear it once every week or so. Now it's about half to a third of the time i turn.
post #6 of 18 Old 12-11-2007, 05:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i've seen ball joints fail on a few vehicles, one was a newer liberty, you don't want this to happen. if you're getting clunking it's bad enough to need replaced soon. usually you don't hear anything with only minimal play in the tires.
ratmonkey is offline
post #7 of 18 Old 12-11-2007, 05:53 AM
Inavacuum
You can do this job yourself for way, way, way less than $850. I ordered all four joints for my ZJ off ebay for $33.99 +s/h. Now I know, and yea they are some cheap brand but they still have a 1 year warranty so I've got a guaranteed year out of them and hopefully if they go out in a year I'll be able to afford some good balljoints. So $40 bucks for the parts and then another $160.00 to rent the press which is all refunded upon return of the press.
http://www.stu-offroad.com/axle/ball...alljoint-1.htm
^ good write up on the procedure.
http://cgi.ebay.com/ebaymotors/4-Bal...2969QQtcZphoto
^ Link to the deal on balljoints.
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline
post #8 of 18 Old 12-11-2007, 07:26 AM Thread Starter
adgjqetuo
adgjqetuo's Avatar
I appreciate the offer, but as cost effective it may be to do it yourself, I don't have the time or the skill to preform the repair. I just wanted to know how bad is too bad and if the fix can wait a month or so until funds are a little better.
But from reading posts, It's probally better to be safe then sorry...even if that means shelling out the money...
Thanks
post #9 of 18 Old 12-11-2007, 07:36 AM
nierace
nierace's Avatar
2003 WJ
The adjustable ones are more expensive and are moog, I think they're like 90 bucks each, which is why I said 200 bucks per side for the parts if you go that route. I wouldn't get cheapo ones, its not a job you want to do more than you have to, I would either get moog or mopar BJ's.
The adjustable ones aren't really adjustable, but you have a option of getting ones that can give you up to 2 more positive degrees of caster on the upper BJ and 1 degree of positive caster on the lower. At stock height though, you would have a bit too much caster. You could compromise and just throw in one adjustable that gives you 1 degree of positive caster. You don't really need them unless you lift above 4"
If his BJ's were that bad that they were near the point of failure I would imagine his mechanic would have said come take a look at this... but who knows.
I would bet they're just worn to the point of where its not sitting quite right/camber is off and is enough to cause poor tire wear...
I've seen some shot to **** BJ's just cause horrible tire wear, but never fail. If your tires aren't getting chewed to **** they can't be that bad. Thats my 2cents
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #10 of 18 Old 12-11-2007, 04:53 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
I decided to take it in, thanks for the advice. Again, better safe then sorry.
post #11 of 18 Old 12-15-2007, 10:22 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
I'm really glad I took it in, WOW what a difference! The steering is tighter and more responsive, and the front end just feels brand new! Bumps, turns, everything. The guy said it's not the worst he's seen, but they were definitly past due. He said while they were under there they tightened everything up, greesed everything, and also replaed a U-joint for me that was going bad.
post #12 of 18 Old 12-15-2007, 10:26 PM
Yardman Harry
O
Thats good to hear! Im happy that things worked out
Ball joints can really do a number to the ride stability and can be seriously dangerous one breaks... I think you made the right choice.
Harry
Hunter Green
White
~Junked~
post #13 of 18 Old 09-15-2009, 02:06 PM
tsvikac
2003 WJ
can i ask from who you buy those adjusable ball joints
how many upper lower ?
THX
TSVIKA
tsvikac is offline
post #14 of 18 Old 09-15-2009, 02:21 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
THX
TSVIKA
This is a two year old thread.
~James
ezflip is offline
post #15 of 18 Old 09-15-2009, 02:23 PM
rugermack
This thread is almost 2 years old.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
Upper ball joints and track bar wasted after 6 months?? aaron7 ZJ Grand Cherokee Forum 11 03-05-2009 05:46 PM
offset upper ball-joints on a wj BransJeep ZJ Grand Cherokee Forum 16 11-02-2008 02:51 PM
Ball-joints ZJPunk98 ZJ Grand Cherokee Forum 21 01-03-2008 04:45 PM
Ball joints. rustycherokee18 ZJ Grand Cherokee Forum 2 02-21-2007 09:13 PM
grease those lower ball joints. 985.9 ZJ Grand Cherokee Forum 7 11-08-2006 12:23 AM
