upper or lower adjustable control arms - JeepForum.com
post #1 of 10 Old 08-15-2012, 10:14 PM Thread Starter
Gibson90kb
I've been looking and looking but do you need both upper and lowers for a larger lift or can you sneak awaywith only the uppers?
Gibson90kb is offline
post #2 of 10 Old 08-16-2012, 06:15 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Both. Nobody said lifting a grand was cheap. Especially if you are at four inches or more.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 10 Old 08-16-2012, 06:25 AM
gotwake81
you can lift it 6-8" on stock control arms. just don't take it off the jack stands....
98 5.9 limited. sponsored by VISA and Krylon. a few bolts are missing....
gotwake81 is offline
post #4 of 10 Old 08-16-2012, 07:53 AM
jtackerman28
Just get an all 8 kit it's cheeper.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #5 of 10 Old 08-16-2012, 08:29 AM
PolkaPower
With a full blown short arm kit you are only a few hundred away from a long arm kit.
PolkaPower is offline
post #6 of 10 Old 08-16-2012, 04:38 PM
sskilla
how large of a lift are you talkin?
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #7 of 10 Old 08-16-2012, 06:15 PM Thread Starter
Gibson90kb
Was aiming for 5 but if thats the limit, ill go big and do a real kit
post #8 of 10 Old 08-16-2012, 06:16 PM
jtackerman28
Do it big!
post #9 of 10 Old 08-16-2012, 06:22 PM
T-nave
I personally got fixed lowers that were the length I needed and got adjustable uppers to be able to dial in the pinion angles. If you are lifting it 5" or more then you better get your wallet out and get a long arm kit. Then plan on getting your wallet out again to buy all the stuff that the kit didnt come with to make it perfect (if your a picky bastard like me).
T-nave is offline
post #10 of 10 Old 08-16-2012, 07:06 PM
sskilla
im on 5 with adjustable front lowers
sskilla is offline
