upper control arm bushings - JeepForum.com
post #1 of 4 Old 02-09-2013, 07:26 PM Thread Starter
dirtdad
'96 ZJ, just replaced the bottom control arm bushings, they were pretty severley cracked. When I removed the upper control arms, the bushings look good, no cracks at all, so I am thinking of leaving them alone, since removing the bushings from the front axle is a pain. Is it normal for most of the wear to be on the lower bushings?
1995 XJ 4.0
1996 ZJ 5.2
dirtdad is offline
post #2 of 4 Old 02-09-2013, 09:15 PM
newfieZJ
Generally speaking , yes . 2 bushings in specific , the 2 axle side lower bushings are the worst . The only upper one that could be an issue is the pass frame side , due to it's close proximity to the exhaust . I only replaced the lower front arm bushings on my latest jeep .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 4 Old 02-10-2013, 09:52 AM Thread Starter
dirtdad
Thats what it looks like, so I am just going to do the lowers.
1995 XJ 4.0
1996 ZJ 5.2
dirtdad is offline
post #4 of 4 Old 02-10-2013, 10:01 AM
riot1987
The only time I replaced CA bushings was axle side. I believe I did uppers and lowers. PITA!
Build thread^^
riot1987 is offline
